Water Pump Seal Replacement - Polaris ATV Forum
Old 06-13-2012, 07:33 PM
mwestwood800HO's Avatar
Member #27205
Hey guys, need to replace my water pump seal on my 2008 Sportsman 800 H.O and was wondering if anyone knows how hard it is to replace and has any step by step instructions on how to do it properly with no issues?
Old 06-13-2012, 07:38 PM
87CYCLONE's Avatar
Member #21964
Ideally there is a special tool you should have to pull the old mechanical seal out. It can be done without it but you really need to be careful not to damage the case or shaft. I would recommend taking it to an experienced mechanic or else purchasing the tool and a service manual!
1987 250-X Cyclone
1987 250 Trail Boss 4x4
Old 06-13-2012, 09:08 PM
AKStew's Avatar
Member #5212
Try reading this it may help.
Water Pump Seal and Oil Seal Replacement on 2006 Sportsman 700 - Pics Inside
Stew
2011 Sportsman 500 HO Touring: Polaris 3500 lb. Winch, Kimpex Adventure XL Trunk, 7" Passenger Foot Risers, UNI Foam Filter
2006 Sportsman 500 X2 EFI: Superwinch Terra 25 w/Synthetic Rope, Kolpin 4 gal Gas Pack, 3" Passenger Foot Risers, 3-Headlight Mod, K&N Filter
SOLD 2010 Sportsman 300: Polaris 2500 lb. Winch, Kolpin Rear Seat (for the dog), UNI Foam Filter
SOLD 2006 Sportsman 700 Twin EFI: 27" Mud-Lite XTR, Superwinch Terra 35 w/Synthetic Rope, Polaris HD Front Springs, OEM Front Bumper Guard, WES Rear Seat, Kimpex Fender Guards w/Footpegs, 3-Headlight Mod, K&N Filter, Symtec Heated Grips
Old 06-14-2012, 02:57 AM
KICKER431's Avatar
Member #18006
Yeah, AKStew's post is a recommended reading. Even if you don't mock up his tool, it will still give you a great frame of reference for when you start tearing into yours. I am stilll looking at doing this on both of my machines some day.
completely stock FOR NOW
26" Maxxis Bighorn 2.0
Old 06-14-2012, 03:49 AM
nicks500HO's Avatar
Member #4101
I just had mine done at polaris for $290 that's including mechanical seal, oil seal, water pump gasket and labour. I tried to find the tool for cheap but it was more than the repair $300+. I didn't want to risk ruining the shaft or anything. Happy searching.
2004.5 Sportsman 500 HO
SS 108's wrapped in 26" XTR'S
K&N Filter
SPX Hand/Thumb Warmers
2500# Warn
Engine Ice
Awaiting Install....
RDC Rad Relocate kit
Custom Snorks
More RDC To Come....
2008 polaris sportsman 500 ho water pump drive seal
2010 polaris sportsman 500 water pump seal installer
2011 sportsman 400 ho waterpump replacement
2011polaris900waterpumpreplaceutube
cost to replace mechanical seal on sportsman 500
cost to replace seal in 2003 polaris 500 ho
how fo replace water pump in a polaris scrambler 500
polaris frontier waterpump seal instal
polaris sportsman 800 water pump seal
polaris sportsman water pump seal
polaris water pump seal replacement
Water Pump Seal and Oil Seal Replacement on 2006 Sportsman 700 - Pics Inside AKStew Polaris ATV How-Tos 35 09-25-2015 03:50 AM
How to Change the Water Pump Seal and Oil Seal on 2006 700 EFI - Pics Inside AKStew ATV Repair and Maintenance 13 07-28-2012 07:50 PM
How do you replace the water pump seal/Mechanical Seal on a polaris 93 350 big boss jwalker89 ATV Repair and Maintenance 2 03-24-2012 07:00 AM
Water Pump Seal cmyers1 ATV Repair and Maintenance 3 09-25-2011 03:53 AM
water pump seal 2003600polaris ATV Repair and Maintenance 2 04-11-2010 09:25 PM
