Old 06-26-2012, 05:07 AM
KevK's Avatar
Member #26280
2012 sportsman 500ho, shifting issues!! help
I have a 2012 500ho with about 500 miles on it. Was riding yesterday, normal riding.. not abusing it.. and it seemed to be not shifting. Won't accelerate over 10mph acting like its on low but is actually on high. Anyone run into this or have any info? Belt worn already??
Old 06-26-2012, 05:21 AM
Old 06-26-2012, 10:32 AM
CaperVandal's Avatar
Member #22600
well as far as I know there isn't supposed to be any shifting other then when you use the lever, but as to your problem.....how's your belt?
2011 Sportsman 500HO
-Big Gun Evo Utility full exhaust system
-K&N oil and air
-Stage 1 Dynajet Kit
-NGK Plug & Race Cable
2012 Sportsman 500 HO Orange Madness LE
-2500lbs Warn Winch
1991 Trail Boss 2x4
-messed up winch
-bent right A arm
-filthy clutch
-ripped seat
-all scratched up
-won't start
-I still like it though
Old 06-26-2012, 11:14 AM
RENOBADBOY's Avatar
Member #23274
Sounds to me like the driven clutch is busted. They have 3 buttons inside that when worn break and don't allow the clutch to operate right.
Old 06-26-2012, 02:16 PM
bgirard420's Avatar
Member #11494
Time to pull the CVT cover and inspect.
Rather be riding, instead I'm using Tapatalk
2013 Polaris XP 850 HO LE EPS
  • Pure Polaris hand guards
  • Polaris L&R rear box
  • Ricochet Ultimate Armor (black)
  • ATV GURU F&R Cobra Brush Guards
2010 Polaris 500 HO
Old 06-26-2012, 05:16 PM
dbmachine's Avatar
Member #23588
thats not alot of miles on a new machine...do you still have stock tires and wheels?
Old 06-26-2012, 10:24 PM
RENOBADBOY's Avatar
Member #23274
All it takes to break these is to spin the tires and all of the sudden gain traction. I know this for a fact!!! That's how mine got broke! But mine broke big time!!! Oh yea, my quad is 16 years old also!!
Old 06-27-2012, 03:43 AM
KevK's Avatar
Member #26280
I know it doesn't shift, I should have worded differently.. I am going to pull cover today and see what is going on in there.
Old 06-29-2012, 06:47 AM
Flyingmonkey's Avatar
Member #27656
It is possible that your belt is worn. I would also check to make sure that you are getting spark as well. I have had both of those issues happen to me and I thought I broke it bad but after thinking about it and checking it was an easy and cheap fix. Let me know how it goes.
2011 polaris sportsman 500 not shifting
2012 polaris 500 ho problems
2012 polaris 500 shifting problems
2012 polaris sportsman 500 belt
2012 polaris sportsman 500 ho problems
2012 sportsman 500ho problems
having trouble shifting polaris sportsman when running
how can you tell if 2012 polaris 500 belt is slipping
polaris 500 ho sportsman problems
polaris sportsman 500 belt problems
polaris sportsman 500 shifting problems
polaris sportsman 500cvt not shifting
sportsman 500 wont accelerate
2005 polaris sportsman 500 gear shifting issues hunter73 ATV General Discussion 3 03-20-2012 12:42 PM
2012 Scrambler 500HO or Sportsman 500HO CJM5404 ATV Purchasing and Price 16 02-29-2012 08:35 PM
2012 500 sportsman down shifting polaris2012500hogreen ATV Repair and Maintenance 2 01-18-2012 08:33 PM
500 sportsman shifting issues mikgro ATV Repair and Maintenance 7 01-17-2011 03:18 PM
2009 550 Sportsman shifting issues Smokepole50 ATV Repair and Maintenance 4 11-30-2010 11:46 AM
