Dies in reverse - Polaris ATV Forum
Old 07-03-2012, 07:02 AM
KSP's Avatar
KSP KSP is offline
Member #27778
Unhappy Dies in reverse
I have a 2001 Polaris Magnum 325. When cold, it stalls immediately when I put it in reverse. Low and High are fine. It seems as though once it warms up it's fine and does not do it. I'm about 99% sure it's electrical because when I disconnect the elec. connectors from the transmission it doesnt do it. (I couldn't find anything on this in the manual?)
Any help greatly appreciated.
Ken
Old 07-03-2012, 09:44 AM
bgirard420's Avatar
Member #11494
Not sure if this model is equipped with a reverse override but it seems like that could be causing a problem if it were broken. Switch is probably bad or even just really dirty. That's where I would start otherwise just don't drive backwards
Rather be riding, instead I'm using Tapatalk
2013 Polaris XP 850 HO LE EPS
2010 Polaris 500 HO
Old 07-03-2012, 11:04 AM
tt425's Avatar
Member #3687
More than likely the rev limiter is bad.
Old 07-03-2012, 11:07 AM
RENOBADBOY's Avatar
Member #23274
I'm thinking a short in the reverse light wiring.
02 polaris scrambler shuts off when put in reverse
atv dies in reverse
polaris 325 dies in reverse
polaris 325 dies when put in reverse
polaris dies when put in reverse
polaris magnum 325 dies in reverse
polaris magnum dies in reverse
polaris magnum dies when i car stalls when put in reverse
polaris scrambler dies in reverse
polaris sportsman dies in reverse
when i put my sportsman 700 polaris in reverse it dies
why does my 02 magnum polaris 325 die when it is put in reverse
dies when put into reverse jimjam ATV Repair and Maintenance 3 05-27-2013 03:27 PM
sportsman 500 dies in reverse brairlakes05 Polaris Sportsman 3 04-06-2011 02:57 PM
dies when i put it in reverse 425whpsti Polaris Scrambler 5 04-01-2011 08:30 AM
Dies in reverse xdarkenagex Polaris Scrambler 4 12-12-2010 04:57 PM
Dies in reverse xdarkenagex ATV Repair and Maintenance 2 05-22-2010 05:34 PM
