2002 sportsman 500 strut assembley for a 2001 sportsman 400 - Polaris ATV Forum
post #1 of 8 (permalink) Old 07-10-2012, 01:17 PM Thread Starter
Tikka338's Avatar
well ordered a strut assembly off ebay..the 2002 sportsman 500 had the same part number as my 01 sportsman 400...upon further investigating i realized that the btb shaft numbers are different for each yr and model was wondering if it should still fit/work or if im wasting my time? will my btb shaft fit and work properly in this 02 500 strut or?
2001 Sportsman 400
Symtec Heated grips & Thumb Warmer
Moose HandGaurds
2000lb Warn Winch
Gun Boot IV - Realtree
Custom Bush Bumper
Tikka338 is offline
post #2 of 8 (permalink) Old 07-10-2012, 02:44 PM
RENOBADBOY's Avatar
You may have to use your axle and bearings. What does btb mean???
RENOBADBOY is offline
post #3 of 8 (permalink) Old 07-10-2012, 03:13 PM
tt425's Avatar
As long as you replace the complete shaft it will work.
tt425 is offline
post #4 of 8 (permalink) Old 07-10-2012, 03:15 PM
tt425's Avatar
Some outer cv joints are stamped "btb" and some are stamed "USA." btb are 2 3/4" diameter and USA(Neapco) are 3" diameter.
tt425 is offline
post #5 of 8 (permalink) Old 07-10-2012, 04:25 PM Thread Starter
Tikka338's Avatar
this is the btb shaft for my 01 sportsman
CV JOINT - BTB - A01CH42AA Polaris SPORTSMAN 400 (A01CH42AA) 2001 OEM Parts - Cheap Cycle Parts
and here it is for the 02 sportsman
DRIVE SHAFT - A02CH50 ALL OPTIONS Polaris SPORTSMAN 500 ALL OPTIONS (A02CH50) 2002 OEM Parts - Cheap Cycle Parts
but the struts seam to be the same with all the same part numbers so i dunno
heres the 01 400 strut
http://www.cheapcycleparts.com/model...trut-a01ch42aa
and heres the 02 500 strut
http://www.cheapcycleparts.com/model...50-all-options
2001 Sportsman 400
Moose HandGaurds
2000lb Warn Winch
Custom Bush Bumper
Tikka338 is offline
post #6 of 8 (permalink) Old 07-10-2012, 04:30 PM Thread Starter
Tikka338's Avatar
so when ordered the strut was hoping it would just connect right in like the other one but now im seeing some difference which i wish i woulda noticed before
2001 Sportsman 400
Moose HandGaurds
2000lb Warn Winch
Custom Bush Bumper
Tikka338 is offline
post #7 of 8 (permalink) Old 07-10-2012, 04:53 PM Thread Starter
Tikka338's Avatar
i was planning on using my bearings and shaft and just putting it into this 02 500 strut will that still work or? will i have to buy the 02 500 shaft or? sure hoping not
2001 Sportsman 400
Moose HandGaurds
2000lb Warn Winch
Custom Bush Bumper
Tikka338 is offline
post #8 of 8 (permalink) Old 07-10-2012, 07:39 PM Thread Starter
Tikka338's Avatar
anyone able to help me s the part i have is 2 hours away from where my qaud is and was wanting to make sure i grabbed all the parts i needed before going out there
2001 Sportsman 400
Moose HandGaurds
2000lb Warn Winch
Custom Bush Bumper
Tikka338 is offline
where to find a new left front strut housing part#1820950 for a 2001 sportsman 400 Tikka338 ATV Repair and Maintenance 6 06-28-2012 04:34 PM
2001 Scrambler 500 Strut/ Hub Problems HELP!!!!!! andrewd523 Polaris Scrambler 4 09-02-2011 06:24 PM
2002 Sportsman 2" coil spring spacer/strut plug forrest411 ATV Brakes & Suspension 3 04-26-2011 04:21 AM
96 sportsman recoil assembley banditboy21 ATV Repair and Maintenance 2 11-15-2010 10:58 PM
WTB: 2001 Scrambler 500 4x4 passenger side strut housing xrocket21 Polaris Scrambler 7 05-20-2010 04:30 PM
