What does it mean when codes are stored but check engine light not on - Polaris ATV Forum
Old 07-12-2012, 10:13 AM
Picpic's Avatar
Member #22123
Hi
If an error occurs in the EFI system the ECU stores error codes in the ECU memory and turns on the check engine light. But does anyone know what it means if error codes are stored in the ECU memory but the check enigne light doesnt come on. Does it means the codes are old, stored earlier but no longer valid or does it mean the error is not qualified enough to turn the check engine light on. Or what does it mean?
Old 07-12-2012, 05:05 PM
BJ2011550's Avatar
Member #25072
The codes are likely old. If the first digit is "0" then it's the oldest...the next error code will start with a "1" and so forth up to 9. (you scroll through with the Mode button)
The next part of the code will be 2-6 digits in length which is the Suspect Parameter Number (SPN).... your manual may give you the fault code issue.
I think the only way to clear the codes is to have the "Digital Wrench"...at the dealer.
If the Check Engine light isn't on then is not currently receiving any faults...assuming the check engine light is working.
Old 07-13-2012, 03:47 AM
Picpic's Avatar
Member #22123
Tannks for reply. Thats what i find most likely also. Check engine light is working cause i pulled out the connector to the tps and then i came on, Put it back and it went off. Thanks.
Jonas
check engine light not on but still has stored code
engine light codes for honda big red
honda big red check engine light
no check engine light but codes
no check engine light but have codes
no check engine light but i have stored codes
stored codes
stored codes but ni cbeck engine light
what are stored codes
what do stored codes mean
what does stored car codes mean
what is a stored code
Check engine light scott_r ATV Repair and Maintenance 11 08-31-2016 08:27 PM
Check engine light came on kbsvo2go Polaris XP 11 07-17-2012 01:22 PM
Check Engine Codes? thole15 Polaris Sportsman 0 02-20-2012 04:02 PM
hot engine check light scarface ATV Repair and Maintenance 18 08-10-2010 10:47 AM
Check Engine Light russell700 ATV Repair and Maintenance 2 10-20-2009 07:24 AM
