800 wont idle but no engine codes - Polaris ATV Forum
post #1 of 6 (permalink) Old 07-14-2012, 12:11 AM Thread Starter
bigtime's Avatar
I had my 2011 sportsman 800 rebuilt for the second time 2 weeks ago and finally got it back. I went on Wednesday for a trail ride of about 90 miles. I went to St. Helen MI and rode from there to Roscommon and back, then to Rose City and back. I had enough time I thought what the heck I will ride to Houghton Lake and back and call it a day.
Well on the way back from Rose City the machine seemed to hickup a little at a couple stop signs but I thought well maybe I am just being paranoid because of all the problems I have had with this machine. Anyway I filled back up with gas in St. Helen at the trailer and took off towards Houghton Lake. At the first stop sign when I stopped it came back to idle and really started chugging and eventually stalled itself out. I restarted it and again it idled for a second then stalled itself out. No check engine light or anything. The next time I tried to restart it, it almost didnt want to go so I headed back to the trailer. Well as long as you are on the gas it is fine it just wont stay running unless you keep it over 2500 rpms.
I loaded it back up and headed home to Birch Run. By the time I got back the motor was cold so I tried to start it again on the trailer. It would roll over but literally would not start until I kept tapping the throttle then it would start. As soon as you let off the throttle it would stall immediately. Still no engine codes or check engine light. I took it back to the dealer immediately since it is still under the extended warranty.
Now I know a lot of guys would probably say its a sensor and I would agree but how come no codes or check engine lights? Back before the first top end rebuild it tried dying twice randomly in a row that day but came back on. No engine codes and no check engine light. The first time for the rebuild was a dead right cylinder that was believed to be due to cylinder wash out from too much fuel. Never did find a cause of it. The mechanic at that dealer said he found that the ECU was never grounded to the chasis.
The second rebuild was due to a bad rebuild the first time and that dealer didnt want to do anything about it just for me to keep adding oil to it. When I told the new dealer mechanic about all that had happened. He is feared that the ECU may not be functioning right. When I first got the machine it would barely idle and would stall unless it was warmed up, the cutting out randomly 2 times, the ground not being connected on the ECU, the cylinder washing out, now it wont idle again after 75 miles on new rebuild and just the general lack of any check engine lights or engine codes.
Do you think he may be on the right track? The only other thing I have done is after the 2nd rebuild I got it home and put my new QSC muffler on it. I was told by Adam and the paperwork that came with it that I didnt need a fuel controller. Like I said it never popped ever and when I got it home and it wouldnt start I pulled the plug on the right cylinder and it was tan so I really dont think that the muffler had anything to do with it. I was a little concerned that if it was too lean I may have burned to exhaust valves but I really dont think any of that happened.
I know he will check it out good and figure out what is wrong but what do you guys think?
Bigtime
2016 Scrambler XP1000
-Original Bighorns
-Garmin Montana 610
-Heat Demon hand grips
-Polaris Ogio rear bag
-Kolpin fuel pack jr.
bigtime is offline
post #2 of 6 (permalink) Old 07-14-2012, 12:39 AM Thread Starter
bigtime's Avatar
Well upon more reading in the forums I found that the symptoms I have are probably caused by a misadjusted ETC. Never even thought of that. I am also betting that will not throw an engine code if it is tripped. Any thoughts
Bigtime
-Original Bighorns
-Garmin Montana 610
bigtime is offline
post #3 of 6 (permalink) Old 07-14-2012, 05:26 AM
SMP63's Avatar
I'd say your right on the money with the ETC needing adjustment!!!!! Also correct about it not throwing codes for that problem.
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
SMP63 is offline
post #4 of 6 (permalink) Old 07-14-2012, 08:30 PM
Picpic's Avatar
Sounds like ETC, had the same problem once, was ETC
Picpic is offline
post #5 of 6 (permalink) Old 07-16-2012, 06:21 AM Thread Starter
bigtime's Avatar
Talked to the mechanic this morning and he did find a code stored in the computer for the TPS. He said while running the machine you could wiggle the wires in the harness for the TPS and the machine would cut in and out and would pop up an engine code for it. Maybe I just didnt see it while riding.
Anyway he repaired the harness and he said he has been running it on and off all morning with no problems. At least it sounds like an easy fix.
Bigtime
-Original Bighorns
-Garmin Montana 610
bigtime is offline
post #6 of 6 (permalink) Old 07-16-2012, 08:23 AM
vortecz71wv's Avatar
Lets hope man! I just fixed the wifes 550 TPS and adjusted it as well as tuned it in on my 800. Way better throttle response now and idles way smoother!!!
Matt
Mine:
2011 Sportsman 800
Polaris Front Brush Guard, Polaris Rear Brush Guard, Polaris Rear Rack Extender, Polaris L&R Rear Cargo Box, Warn 2500lb winch, Winch Saver, Ricochet A-Arm Guards (www.TheATVSuperStore.com), 3-High Headlight Mod, 6000k HID kit, Rigid Ind. 2xDually w/ strobe box, UNI Air Filter, 26" GBC Dirt Commanders, 1" Billet Wheel Spacers (Front and Rear) HighLifter HD springs, Dalton Primary Spring O\BL, Realtree Seat custom cover, Polaris Handguards
Wife's
2011 Sportsman 550XP
Polaris Front Brush Guard, Polaris Rear Brush Guards, Polaris Rear Rack Extender, 26" GBC Grim Reapers, Viper Elite 3000lbs Winch w/ wireless, Polaris Handguards, 6000k HID Kit
Fuel It, Flog It, Feel It!
vortecz71wv is offline
engine codes Nobike Polaris XP 4 10-20-2014 02:19 PM
1995 Sportsman 400 4x4 wont idle but will get scary off idle. darrin5 ATV Repair and Maintenance 5 02-27-2012 07:01 AM
Check Engine Codes? thole15 Polaris Sportsman 0 02-20-2012 03:02 PM
reading engine codes? nvhunter Polaris XP 1 07-05-2011 07:42 AM
2005 sportsman efi 700 engine codes 21 and 42 and 4wd inop hammerhead Polaris Sportsman 0 05-03-2010 04:33 PM
