02-23-2010, 01:34 PM
Member #2472
What is the correct Oil Filter ???
Does anyone know what the correct oil filter is for a 2005 sportsman 700 twin?
I can't find it anywhere.
02-23-2010, 02:04 PM
Oem # 2540086
02-23-2010, 02:27 PM
Member #2472
ok thanks. Do you know of any after market filters that would work?
02-23-2010, 02:37 PM
Hi Flo- HF198 (kick ass filthers)
K&N- KN198
NAPA- 1356 or PS1356
FRAM- PH6014A
WIX- 51356
02-23-2010, 02:56 PM
Member #2326
Hey blue you should post #'s for other models are well. I know a lot of models take the same filters. Maybe get it as a sticky?
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
YouTube Channel: www.youtube.com/user/tinkerman01
02-23-2010, 03:01 PM
Member #2472
Hey blueline, whats the difference between the wix 51356 and the 51357? Wix has the 51357 listed for 700 and 51356 for 800 but i dont see a difference. WIX Filters : Filter Look-Up
02-23-2010, 03:03 PM
Member #2472
02-23-2010, 03:40 PM
Member #2472
also on the kn-198 it says built after 10/8/04 but what about before? Mine was built on 9/7/2004 and i think i would prefer a k&n filter
02-23-2010, 03:48 PM
i dunno what wix's deal is, sometimes aftermarket companies do that. as far as polaris is concerned, (does not include outlaw, predator, or 90cc and under) you have two filters...single cylinder and twin cylinder.
for 300cc and up single cylinders it is OEM# 3084963
for 600cc and up twin cylinders it is OEM# 2540086
for predator 500 and outlaw 500 it is OEM# 3088036
for all outlaw 525 KTM motors it is OEM# 2520754 and OEM# 2520755 (twin oil filtration system, two different oil filters side by side)
that is it. those are all the oil filters i think.
02-23-2010, 03:50 PM
no worries about that, same deal when you look on the polaris dealer microfiche. it gives you a build date with two different oil filters, but they both superseed into the same filter. you dont have to worry about the build date anymore, they all use the same filter
2004 polaris 600 sportsman oil filter, 2004 polaris sportsman 600 oil filter, 2005 polaris sportsman 600 twin oil filter fram, 2005 polaris sportsman oil filter walmart, fram kn-198, fram oil filter 2005 polaris sportsman 700, fram oil filter for a 05 sportsmen 700, ktm 525 oil filter wix, oil filter 2006 polaris 700 sportsman autozone, oil filter number for 2005 polaris sportsman 700, oil filters for atv in alabama, polaris 525 oil filter location, polaris hawkeye oil filter fram, polaris outlaw 500 oil filter, polaris outlaw 525 oem oil filters, polaris outlaw 525 oil filter, polaris sportsman 600 oil filter, polaris sportsman 700 oil filter, where is the oil filters polaris outlaw, wix oil filter number for 04 polaris sportsman 600 twin
