clutch buttons - Polaris ATV Forum
Old 07-31-2012, 01:27 PM
elkierider's Avatar
Member #28610
clutch buttons
Does anyone know what causes the clutch buttons to fail? I will be on my second set in a little over 2 months. I was just coasting down a power line when I got to the bottom I hit the gas and I noticed the machine wasn't sounding right. When I got to 20 mph it would not accelerate any further. Being I just had them replaced I knew what was wrong. Any advice would be greatly appreciated.
Old 07-31-2012, 01:45 PM
4getful2's Avatar
Member #1234
When i replaced mine, i filed and emory clothed the helix and sheave until very smooth, kinda important to get all the gouges out.
If it rolled over(spring lost it's preload),Possibly your helix itself is too worn down .
Old 07-31-2012, 04:49 PM
Old 08-02-2012, 10:28 AM
PLUMMER's Avatar
Member #4033
Helix never wears, they only get damaged. good idea to smooth out the ramps, but they all have to be perfectly even for smooth shifting. Hopefully they didn't put in new buttons with a damaged helix. severe bearing wear or a broken secondary spring can cause the sheaves to bang or ride very unevenly putting all the load on 1 button, once 1 goes the other 2 go fast. I don't suggest repairing rebuilding a secondary if its more than bushings or a helix. Replacing bushings just buys u more time. Miles? any sheave wear?
2001 SPORTSMAN 500 HO REMINGTON SPECIAL EDITION
FOOD PLOTTER, WORKHORSE, TRAIL BREAKING HUNTING MACHINE
CLUTCH WORK SET TO "TRACTOR"
Old 08-02-2012, 12:58 PM
elkierider's Avatar
Member #28610
Old 08-03-2012, 05:39 PM
sportsman010's Avatar
Member #13889
i have a 98 sportsman 500 with 7k and wont go over 20. im hearing and reading about the clutch buttons, just one ? where are they, what r they and how hard are they to replace?
Old 08-03-2012, 06:13 PM
bgirard420's Avatar
Member #11494
They are in the secondary, are what the helix "grabs" to make the bike move and are resonably easy to replace provided you have the tools needed to do it.
2013 Polaris XP 850 HO LE EPS
2010 Polaris 500 HO
Old 08-03-2012, 11:07 PM
RENOBADBOY's Avatar
Member #23274
The three buttons are a nylon type material,held in with torx type screws. The helix and the spring pressure are what holds this all together. If the spring isn't right it won't drive properly.
Old 08-04-2012, 07:23 PM
Member #13889
my ? is how do you remove the clutch buttons? is it simple to do or a real pain in the ass? and the clutch buttons are in the primary drive clutch right? any advise would be very helpful. Thanks.
Happy riding!!!
Old 08-05-2012, 12:49 AM
RENOBADBOY's Avatar
Member #23274
The buttons are in the rear clutch. Not hard to fix if all other parts are ok. There is a video on youtube showing how to do this, very informative. Give a yell if you need more help.
08 500 polaris ranger clutch buttons
how do you remove the clutch buttons on a gator
how to put new buttons in polaris clutch
how to replace polaris clutch buttons
polaris clutch button replacement
polaris clutch buttons video
polaris primary clutch button replace
polaris sportsman clutch buttons
purpose of clutch on atv
remove button ramps on polaris clutch
will a missing clutch button mess up my polaris ranger
Changing the clutch buttons. 3 Polaris Atvs ATV Repair and Maintenance 10 06-03-2014 06:13 AM
WTS: EPI clutch kit, 04 brush guard, and driven clutch assembly Redneckbmxer24 ATV Parts for Sale 8 06-11-2012 03:28 PM
93 350L Drive Clutch and Driven Clutch Removal dpherll ATV General Discussion 1 11-24-2011 07:05 AM
Primary clutch squeak after installing clutch kit x omerta x Polaris Sportsman 20 08-10-2010 02:46 PM
Rubber seat buttons rookie racer Polaris Sportsman 7 04-21-2010 06:20 AM
