98 425 magnum fuel pump diagram - Polaris ATV Forum
post #1 of 5 (permalink) Old 02-25-2010, 06:25 PM Thread Starter
bigdaddy's Avatar
I just bought a 98 425 magnum 4x4 and was wanting to know if someone had or knew were each of the lines that come off the fuel pump are to be connected in order for it to work theres 1 line on the top of the fuel pump and 2 on the bottom side but not sure which ones are to go to the carb for suction and which one is to go to the tank it's self and the schematics I am pulling up for the parts list isnt showing me what I am needing to see
bigdaddy is offline
post #2 of 5 (permalink) Old 03-31-2010, 07:41 AM
frisbie's Avatar
did you find out how they go i would like to know...thanks kevin
frisbie is offline
post #3 of 5 (permalink) Old 03-31-2010, 02:44 PM
Spitfire79's Avatar
The one on top goes to the right side of carb (by your right leg) This is vacuum. The 2 lines on the side of pump should have arrows for in / out
Spitfire79 is offline
post #4 of 5 (permalink) Old 03-31-2010, 03:59 PM Thread Starter
bigdaddy's Avatar
yes if your looking at the pump mounted on the top the very top line is the pulse line the one directly below it is the line to the carb and the one closest to the front of the quad goes to the fuel tank your pulse line runs to the right side of the carb and the fuel line runs to the left side as you are setting on the quad
bigdaddy is offline
post #5 of 5 (permalink) Old 05-01-2010, 04:52 AM
buckfever5's Avatar
Send a message via AIM to buckfever5 Send a message via Yahoo to buckfever5
I just want to clarify, because I think I found the problem with my quad.
The fuel supply line that goes in to the carb is located on the lower side of the carb, and feeds in to the bowl where the float is located. The pulse line goes into the upper side of the carb on the right hand side? Please let me know if I am understanding this correctly.
buckfever5 is offline
oil injection pump frony83 ATV Repair and Maintenance 4 05-19-2015 09:37 AM
01 Trailboss 325 Fuel Pump Problem ? greg617ma ATV Repair and Maintenance 5 10-23-2013 05:56 PM
96 Magnum 425 Electrical diagram Ragin Cajun ATV Repair and Maintenance 0 10-29-2009 12:04 PM
2001 Polaris Magnum 325 2x4 leaking fuel cl0848 ATV Repair and Maintenance 3 09-21-2009 02:00 PM
2006 Sportman 700 fuel pump problem MesaRider Polaris Sportsman 9 08-24-2009 09:48 AM
