2000 trailblazer new battery no start clicking - Polaris ATV Forum
Old 08-11-2012, 12:48 PM
scottg33's Avatar
Member #27253
new battery all i get is clicking when trying to start help....
2000 trailblazer 250
progrip grips
fmf fatty gold series exhaust
wiseco pistons 76.oomm
quad boss drive belt
dirt devil II rear tire
pbm performance parts
K&N air filter high flow
volar chain
Old 08-11-2012, 04:21 PM
Boburk's Avatar
Member #28136
New battery charged? Voltage on the new battery?
Normally, clicking from the solenoid with no starting is either a bad battery, discharged battery, or bad battery connection. It can be a bad solenoid or bad starter, but power is a more common problem.
If you are not sure of the charge status of the new battery, try jump starting it. I did this using my riding mower to jump my 2008 sportman. Started right up. Changed the battery and all is good.
On a side note, buddy of mine got a "new/charged" battery for his Yamaha from the dealer. When he got it home it would not turn his bike over. He noticed it had no acid in it yet. So much for them charging it for him...
Sean
_____
2008 Sportsman 300
- Purchased in 2012 with 25 hours on it
- UNI air filter
- Polaris 1500 winch
2011 X2 550
- Purchased in 2012 with 58 hours on it
- Viper 3500 winch
- Front lock and ride storage box
- Bighorn 2s all around
2012 RZR 570
- Purchased Dec 2013
- Viper Elite 3500 winch.
- Cooter Brown top
- EMP rear window
- Totron 30" curved spot light bar
2006 X2 500 (sold)
- Purchased in 2011 with 250sh hours and 2500sh miles
- 26" Trilobite HD tires on 12" SS108 rims
- Cabela's (Warn RT) 2500 winch
- Front rack extender
- Front brush guard
Old 08-12-2012, 05:56 AM
scottg33's Avatar
Member #27253
come to find out it isn't the battery pull start fires rt up but it's the starter...how hard is it to do
progrip grips
volar chain
Old 08-12-2012, 06:46 PM
animalcrackerz's Avatar
Member #28974
Starters are pretty easy to do
Sent from my Lifeproof iPhone using Tapatalk
Old 08-12-2012, 06:52 PM
scottg33's Avatar
Member #27253
i hope its not the starter anything else i can do to check silenoid that seems to be easier fix will they still click if there bad dont know reading on battery just stressed cause i min. it started fine then the next clicking not real mechanicly incline so big deal for someone who dont know anything bout these thing 1st atv and info or help is thankful
progrip grips
volar chain
Old 08-12-2012, 06:55 PM
scottg33's Avatar
Member #27253
it actually was clicking before i replaced battery went to polaris dealer bought new battery saleman said battery was good bout 75% charged new that dont make much sense thought new battery should be 100% still clicking after put new battery on so put old battery back and was going to return it if they will take it back
progrip grips
volar chain
Old 08-13-2012, 04:46 AM
Member #28974
You can put a screw driver between the two points on the seloined and then the starter should turn over.if the starter does work then that tells you that the seloined is bad, If not then its more than likely the starter.
Old 08-13-2012, 08:03 AM
Was the old battery load tested before replacing? About the only batteries that come close to 100% are the gel batteries. If you got the direct replacement acid based battery, they never get to 100% charged on their own when new. They usually have enough juice to get the machine going one time, otherwise, they need the help of a battery charger to top them off when they're new. The guy was right.
As said above me, try jumping the solenoid.
Old 08-13-2012, 01:19 PM
scottg33's Avatar
Member #27253
got charge on battery going to see what happens not for sure how or the rt way to jump silenoid gonna give it try hope thats what it is
progrip grips
volar chain
Old 08-13-2012, 01:42 PM
scottg33's Avatar
Member #27253
tried to start yesterday morning it started to turn over then just click at silenoid does that mean starter is good and it's the silenoid
progrip grips
volar chain
2000 blazer wont start and clicks starts fine after jump
2000 polaris trailblazer 250 battery
2000 polaris trailblazer 250 starter
2000 polaris trailblazer click but no start
2003 polaris trailblazer 250 battery
battery clicking
polaris trailblazer 250 clicking when trying to start
polaris trailblazer 250 starter solenoid
polaris trailblazer that this clicks
put new battery in atv and solenoid clicking
starter solenoid clicks 1997 polaris trailblazer
trailblazer 250 clicks when trying to start
outlaw 50 clicking but wont start please help cobra3992 ATV Repair and Maintenance 1 11-26-2011 08:02 PM
1996 polaris sportsman 400 clicking when i try to start it cravenddb ATV Repair and Maintenance 1 11-20-2011 09:28 PM
2003 Trailblazer 400 clicking and more bigvin21 ATV Repair and Maintenance 0 10-06-2011 05:01 AM
Clicking, lots of power no start rottie ATV Repair and Maintenance 7 04-19-2011 01:41 PM
08 x2 clicking no start Goose ATV Repair and Maintenance 2 05-26-2010 04:29 AM
