98 Scrambler 400 no low end power - Polaris ATV Forum
Old 05-18-2009, 12:57 PM
outdoorsol's Avatar
Member #478
i have a 98 scrambler 400 4x4 when i press the throttle the enginge bogs down and i almst have to push the machine to get it to move. any suggestions
Old 05-18-2009, 02:26 PM
clutchman's Avatar
Member #291
as always, check the carb
the first place i would start is with the carb. if it will crank and stay running i would bet its the carb. you may need to remove and clean. if it been sitting for a while or has a dirty air filter it may have trash in it or just gummed up. its hard to tell you for shure, it could be a few things but i would start there. hope this helps and good luck
2002 polaris scrambler 500 has no power
98 polaris scrambler 400
98 polaris scrambler 400 no power
98 scrambler 400 clutch bog
atv no low end power
polaris 400 bogs down on low end
polaris 400 has no low end
polaris 400 low end
polaris low on power 350
polaris no low end power
polaris scrambler 400 no low end power
scrambler 400 low end bog
