2006 Polaris Sportsman X2 Front Wheels not spinning in AWD
Hi everyone, I just got a used 2006 Polaris Sportsman X2 and went to do the front differential oil change. I removed the drain plug and no oil came out. There was just some mud. I went ahead and put in the 6oz of on-demand oil to see were the oil leak is. It seems to be coming out where the drive shaft comes into the differential unit. I have the ATV jacked up, so I started it up, put it in high and AWD. The AWD indicator appears on the display. I give it some gas and the rear wheels will spin, the drive shaft to the front diff is spinning, but the front wheels are not doing anything. I swear it seemed like the AWD was working but I guess I made a bad mistake. I have seen some different posts about the front diff problems, but these 4wd atv's are new to me and I just need some ideas and prayers that this isn't going to kill the pocket book. Any help would be greatly appreciated. Thanks a lot.
