4WD wont engage, any help? - Polaris ATV Forum
post #1 of 3 (permalink) Old 09-08-2012, 08:48 AM Thread Starter
Rango's Avatar
The 4WD on my '09 Sportsman 500 works fine as long as the icon on the instrument panel is on. The icon goes out and the front wheels wont engage.
Rango is offline
post #2 of 3 (permalink) Old 09-08-2012, 09:08 AM
Carrotchariot's Avatar
I'm not too familiar with the newer transmissions, but on the older (pre 2000s) I've had issues with engagement, what you can first try doing is taking the shift lever linkage off and manually move the lever on the transmission into the 4wd position. if it stays in 4wd then you need to adjust the linkage length, if it slips out you have rounded gears/ cogs from being out of adjustment. you will need to pull out the transmission and replace the worn parts
Carrotchariot is offline
post #3 of 3 (permalink) Old 09-08-2012, 04:06 PM
Muggzy's Avatar
This could also be a symptom of an electrical problem. The icon's going out b/c power to the lamp from whatever is controlling it (and the AWD) is being lost. Follow the logical path back from the light. It may or may not be electrical but you just need the schematic for a place to start and it'll take you to the problem anyway
'01 Polaris Sportsman 500 HO project (needs a 'lil TLC. OK, OK, a LOT of TLC)
My first 4WD ATV!
1" wheel spacers, 25" STI Black Diamond Tires, Front and rear storage with seat.
My other ride is a 2-stroke sport quad.
Muggzy is offline
00 sportsman 335 4x4 wont engage vortecman07 Polaris Sportsman 16 01-24-2013 12:06 AM
00 sportsman 335 4x4 wont engage vortecman07 ATV Repair and Maintenance 0 02-25-2011 06:35 PM
08 Sportsman 800 4x4 wont engage frazier Polaris Sportsman 13 01-30-2011 10:50 AM
trailboss 4WD wont engage jeepster651 ATV Repair and Maintenance 2 08-10-2010 09:41 AM
05 sportsman 4x4 wont engage mikgro ATV Repair and Maintenance 2 09-13-2009 01:49 PM
