Old 09-11-2012, 10:10 AM
jordaman17's Avatar
Member #13240
Cool Polaris Xplorer 400 clutch problem...
can someone tell me what is wrong with this thing? the belt goes halfway up the primary then over revs. i put on a different primary and it's the same thing, also replaced the spring and buttons in the secondary. Any help would be great.
5140km 2008 Polaris Sportsman 500 Ho, Polaris Hand & Thumb warmers, RotoPax 4 Gallon Fuel Pack, Custom Made Rear Bumper, PowerMadd Hand Guards, Polaris Rear Work Lights, Ricochet Ultimate Armor, Modified Stock Muffler, Polaris 3500lb Winch, Rear Rack Extender, Super Atv 2" lift kit, Polaris Brush Guard, 3 Headlight Mod, Uni Air Filter, EPI 'patv1' primary clutch spring. All up on Interco Swamplites! Maintenance is the key to a never ending happiness
Check out my youtube channel! ---> http://www.youtube.com/user/mudsling...ew=0&flow=grid
Old 09-11-2012, 11:52 AM
InRBigness's Avatar
Member #7218
If you have replaced the buttons already,then you have over tightened the spring or tensioned it the wrong way when you put it back together. The sheaves on the secondary should be spreading apart as the primary makes the belt tighter. They are not. It is definately a secondary problem.
On my old 400's you just needed a bit of preload on the spring and my 500HO needed none. Just put it in the holes marked "2"
2012 Starfire Blue Sportsman 850XPHO LE EPS:
- Fender/ Rack guards, 3500lb PolarisHD winch, Polaris hand and thumb warmers, Powermad hand guards, HID lights, ATV Guru Front Guard, Ricochet A-Arm guards, front Lock and Ride box, Uni Air Filter. 27" Black Diamonds Radials, Odyssey Battery
2012 Bronze Mist Sportsman 850XPHO EPS
- Fender/Rack guards, 3500lb PolarisHD winch, Polaris hand and thumb warmers, Powermad Hand guards, HID lights, ATV Guru Front Guard, Ricochet A-Arm guards, Front lock and ride box, Uni Air Filter. 27" Black Diamond Radials, Odyssey Battery
2008 Red Sportsman 500HO
-STI Black Diamond radials on STI rims, Kimpex box with seat, Rack/Fender guards w/passenger pegs, Uni Air Filter, HID lights, Ricochet A-Arm guards, Polaris 3500HD, Polaris hand and thumb warmers EPI Front and rear clutch kit.
Old 09-11-2012, 12:10 PM
jordaman17's Avatar
Member #13240
i can assure you there in the "2" holes, had it apart twice.
Old 09-11-2012, 12:24 PM
InRBigness's Avatar
Member #7218
Did you pretension it before putting back on the snap ring? Can you take your hands and make it open up? If you cant then somthing is either broken or binding.
Old 09-11-2012, 01:39 PM
Kevcules's Avatar
Member #14887
Was it doing the same thing it is now ,before you changed the secondary spring and buttons? Maybe you installed a stronger spring than you're supposed to?
I believe it's the secondary clutch as well.
To rule out the primary though, take off the belt and rev the engine up and down. Does the primary clutch move in and out at least an inch? If it does , then it's probably OK....
You will have to investigate the secondary some more. Like the previous poster said, you should be able to push the inner sheave in with your hands. If you can't , then the belt can't....
If you disassemble the secondary and the sheave moves up and down freely , then it's probably a spring tension issue.
Great video by the way!!
Kevin
Old 09-11-2012, 03:40 PM
jordaman17's Avatar
Member #13240
it messed up earlier, then we put the new parts in the secondary, it was fine for probably 4 months now it does this. primary fully closes with the belt off. guess i will explore the secondary further.
Old 09-11-2012, 04:43 PM
InRBigness's Avatar
Member #7218
Well if it worked for a while and then stopped after you fixed it, then open it up and see whats going on inside. Maybe a screw came out of one of the buttons or???? It is definately in the secondary.
Old 09-12-2012, 12:10 AM
jordaman17's Avatar
Member #13240
i took it apart again once this happened, didn't see anything wrong, will look again.
Old 09-12-2012, 12:21 AM
jordaman17's Avatar
Member #13240
wish i could find a used secondary, save me messing with this one anymore.
Old 09-12-2012, 07:16 AM
Kevcules's Avatar
Member #14887
There's very little going on inside the secondary clutch assembly. I wonder what the problem would be?
Do you still have the old spring? Did you change it because it was broken? Can you bring your secondary assembly to an ATV shop for someone to look at?
Kevin
2001 Sportsman 500 HO
Famous saying......" I'm going to the garage" !
1999 polaris 400 clutch slip
99 polaris explorer 400 clutch cover
best clutch spring for polaris 400 xplorer
clutch slipping on 94 polaris
fix clutch on atv polaris 400
fixing polaris xplorer 400
polaris 400 belt and clutch locks up when riding
polaris 400 clutch
polaris 400 clutch problem
polaris explorer 400 reeds
polaris ranger 400 problems
polaris ranger clutch problems
polaris xplorer 300 clutch issue
polaris xplorer 400 secondary clutch
polaris xplorer problems
Polaris Xplorer 400 Electrical Problem dicksonbr ATV Repair and Maintenance 4 10-01-2012 12:25 PM
polaris xplorer clutch? jordaman17 ATV Repair and Maintenance 4 07-05-2012 05:06 AM
Pull Clutch on a 1994 Polaris 400 Xplorer StarGazed0123 ATV Repair and Maintenance 3 01-23-2012 08:23 PM
1997 Polaris Xplorer problem Kevin147 ATV Repair and Maintenance 0 10-11-2011 11:15 AM
1997 Polaris Xplorer Steering problem Kevin147 ATV Repair and Maintenance 7 07-17-2011 09:51 AM
