03 sportsman 700 headgasket?? - Polaris ATV Forum
Old 09-13-2012, 10:22 PM
nhazy's Avatar
Member #29996
hey guys new to polaris but not atvs. I have an 03 sportsman 700 that is losing coolant some where i can't find any leaks but a milky grey oily liquid is coming out of breather tube from engine into airbox. have not drained oil yet but am thinking headgasket right? any help is welcomed thanks. oh yeah engine seems to run fine but have not run since i found that don't want anymore damage . don't hear a knock at all.
Old 09-14-2012, 04:03 AM
Member #1958
After it sits for several days, if you remove the oil drain plug slowly it should drip coolant first since it will settle to the bottom. Could be several things but probably base gasket and/or head gasket would be my guess.
Old 09-14-2012, 05:52 AM
Tags
cooling, head gasket, sportsman 700
03 700 sportsman blown head gasket
03 sportsman 700 headgasket replacement
2004 polaris sportsman 700 head gasket
base gasket leak fix atv
head gasket removal sportsman 700
how long does it take to change a head gasket on a polaris 700 sportsman
how to change head gasket on polaris 700 sportsman
how to change head gasket on sportsman 700
polaris 700 head gasket
polaris 700 sportsman head gasket replacement
Blown headgasket on 500HO thethrill Polaris Sportsman 2 08-07-2012 01:20 PM
