03-03-2010, 02:51 PM
Member #3239
04 600 sportsman bogging out
Hey guys, I knew when I joined I should have never said Polaris gives me no problems without knocking on some wood.....but it finally did. I'm hoping it's minor. The machine runs like it should until you hammer the throttle then it bogs so bad it almost dies, let off and it purrrrrs. Runs great at low speeds/rpm, but high speed/rpm just ain't happening. I'm hoping to look into it this weekend. So much for weekend camping. But hey, my wife's 600 is fine, I wonder how far out the garage I'll get with it......hee he
cheers,
nowhereman
03-03-2010, 02:58 PM
Member #2326
Have you checked the air filter? Check for any clogs in the air box intake tube..
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
YouTube Channel: www.youtube.com/user/tinkerman01
03-03-2010, 02:59 PM
Member #1634
did this happen all at once or did it get worse over time and is it carb or efi im guessing its carb. if it happened kinda quick and you havent driven it check your airfilter might have mice nest in there or you exhaust too.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
03-03-2010, 03:36 PM
first check to make sure your air filter is clean and replace if in doubt as stated below. the next step would probably to clean your carb
03-03-2010, 06:00 PM
Member #3239
Thnx all, It has a carburetor. Yea I checked the air cleaner as a pre-ride walk around check, seemed ok. Will probably change it now. It started fine and ran ok when loading, but I didn't really cowboy it at this time. Once unloaded and ready to hit the trail is when I noticed the bog. I did put gas in it from a can that was probably 3 months old, so that may have something to do with it. Have not checked for a clogged air box inlet. Thnx for the ideas
cheers,
nowhereman
03-03-2010, 06:22 PM
yes, that was probably your problem right there. with fuel stabilizer fuel that old is bad for your machine. now im guessing the carb needs cleaning
03-04-2010, 03:05 AM
Member #2469
I had to change out the main jet and needle for the jet kit I bought and I was amazed how filthy the carb was. I'm actually surprised it was still running. It was the first time the carb has been off my 04, so yours (nowhereman) is also probably due for a cleaning.
04 Sportsman 600
Big Gun exhaust, UniFilter, DynoJet, QSC clutching, Highbeam mod, reverse override, 14" ITP SS108, ITP XTRs 27-9-14 / 27-11-14
03-04-2010, 07:08 PM
Member #3239
yeah, I'll take the advise and plan on doing a carb clean and new air cleaner. I'll probably do both ATVs, they are twin 04 600 sportsman. Thnx for your replies.
cheers,
nowhereman
03-07-2010, 09:32 PM
Member #3239
Nice day to be in the garage, so I cleaned the air box, checked for clogs, cleaned the filter sock, replaced the air filter, put in fresh gas. Still bogs bad at about 25mph. Removed the carb and stripped it down for a good bath, still bogs. Replaced the spark plugs, same problem. Machine starts like a champ and runs perfect at low speeds, even has good power. I wonder if spark plug wire resistance is breaking down at higher rpms? Anyone have ideas or experience this problem and have a fix? I ran it by my local shop and of course all they wanted was for me to bring it in...This problem just happened all of a sudden to. Had no problems on last trail ride, parked it, took it out for a ride and bam, problem. Thnx for any help guys.
cheers,
nowhereman
03-13-2010, 02:24 PM
Member #3239
An update on my progress.
Well, I know it's not plug wires now....the next thing I'll try is adding a little 2 cycle to the gas, a friend thinks it might be a sticky valve??? I don't think it's the cam, there is no popping or backfiring. Open to ideas.
cheers,
nowhereman
04 polaris magnum jetting, 04 sportsman 600 bogs, 2004 polaris 600 carb adjustments, 2004 polaris 600 sportsman bogs out, 2004 polaris sportsman 600 carb adjustment, 2004 polaris sportsman 600 carb cleaning, 2004 polaris sportsman 600 carburetor rebuild kit, 2004 polaris sportsman 600 carburetor rebuild kit#gsc.tab, 2005 polaris sportsman bogging, 96 polaris sportsman 500 what will it cause it to bog at high rpm`s, atv boggs down at higher rpms, cleaning the carb on polaris 600 sportsman, my 2011 polaris sportsman is slipping or bogging down at high speeds, polaris magnum air box cutting back, polaris sportsman 600 bogging, polaris sportsman 600 carburetor upgrades, polaris sportsman bogging when i gun ir, polaris sportsman has no high speed, sportsman 600 bogs warm, sportsman 600 carburetor
