Old 03-04-2010, 01:41 PM
broken's Avatar
Member #3430
4x4 = all good?
2002 700 sportsman, when switch is in 2x4 mode, when spinning rear tires in the snow the front tires will start to spin also, is this normal?
Old 03-04-2010, 02:42 PM
yes, this is normal. even on the new machines, you can get the fronts to kick in while in 2wd by getting the rears to spin fast. it has happened to me, its just the way the system works.
Old 03-04-2010, 07:59 PM
is this noise happening when the wheels are spinning on ice in 2wd?
Old 03-05-2010, 03:11 PM
broken's Avatar
Member #3430
the noise is coming from a worn out u-joint in the rear, thank you for the ideas
are polaris 4x4 atv's any good?
polaris 4x4 atv any good?
polaris 4x4 atvs any good
worn rear polaris u joint
See any good movies lately??? redneck2725 Around The Garage 6 07-04-2011 01:35 AM
master cyl good grief bomberboat ATV Brakes & Suspension 13 03-23-2010 09:47 AM
Good Day BarnyBee ATV New Members 4 03-04-2010 10:01 PM
Good Battery Gone Bad MN Matt ATV Repair and Maintenance 11 02-10-2010 12:43 PM
Is This A Good Deal for '09 Sportsman 500 X2 a12 ATV Purchasing and Price 7 09-13-2009 02:42 PM
