Old 03-04-2010, 05:50 PM
eidsonben's Avatar
Member #3474
Blown fuses
I have a 800 sportsman and it keeps blowing a main display fuse which shuts the whole bike down. I have checked all the wires what is my next step it only blows every now and then.
Old 03-04-2010, 05:55 PM
no bare wires anywhere that are shorting out?
Old 03-04-2010, 06:01 PM
eidsonben's Avatar
Member #3474
NO BARE WIRES AT ALL. An it only blows occasionally
Old 03-04-2010, 06:06 PM
is there any kind of consistancy to it? onces you get to X amount of speed, X amount of riding time, turn headlights on, anything that makes it consistant, or just absolutley completely random?
Old 03-04-2010, 06:17 PM
eidsonben's Avatar
Member #3474
It has done it three times since last october but I haven't rode much since then. It seems to happen after a right hand turn. My buddy and I have narrowed the circuit down to the main power circuit with the key switch and kill switch on it. When it it blows it is just like you reached down and turned the key off.
Old 03-04-2010, 06:39 PM
broken's Avatar
Member #3430
blowing fuses
i had the same problem this winter while plowing snow, found very dirty or mudddy at fuses, pressure washed and put dialectric grease on fuses,[ very small amount] have not blown a fuse since i did this,hope this will help, signed broken
06 polaris sportsman main fuse location
09 sportsman 90 fuse size
atv blown fuse
atv fuses
blown fuse on polaris outlaw 90
fuse size for polaris outlaw 90
how much is a fuse for a polaris 50
main fuse picture for polaris ranger 2010
olais outlaw 90 fuse keeps blowing
outlaw 90 blowing fuses
polaris 90 blowing fuse
polaris 90 blows fuse
polaris 90 starter blowing fuse
polaris outlaw 90 fuses
polaris outlaw 90 keeps blowing fuses
polaris outlaw fuse where are fuses located?
polaris outlaw fuse where located
polaris sportsman 800 keeps blowing main fuse
polaris sportsman 800 main fuse
Blown head gasket??? Jeff Wright Polaris Sportsman 5 09-04-2010 07:32 AM
Fuses fourlayne ATV General Discussion 0 11-22-2009 03:12 PM
