06 sportsman 800 won"t shift - Polaris ATV Forum
Old 03-05-2010, 05:09 PM
rookie racer's Avatar
Member #3491
Ok all you experts- Just bought a 2006 sportsman 800 today from a dealer. took a ride, could not shift the gears{ yes its auto} unless you shut the engine off then i could change gears. sales person said its the drive belt. so he gave me a new one . i took it home changed the belt , No Change, CRAP !!! They are going to look at it tommorrow. WHAT IS WRONG !
CHUCK
Old 03-05-2010, 08:09 PM
this sounds txt book! belt tension adjustment. now, im not exactly sure how to do it, or how to explain it, but if the belt tension is too tight, the machine will not shift into gears while its running, but will shift when it is off. sounds exactly like your problem. takes about an hour for a experienced mechanic to properly adjust belt tension....no biggie really, fairly common to see at the shop, see 2-3 a month with the exact same problem.
Old 03-06-2010, 12:17 PM
Member #3491
Thanks a bunch for the quick reply. I will post results.
Old 03-08-2010, 06:51 PM
Member #3491
Its fixed, Iam sooooo happy! no more squealing, i can shift the lever now. Dealer said the tapered washer was put on backwards on the clutch. new belt runs great.
2006 sportsman 800 EFI camo
Old 05-29-2011, 01:42 PM
Polaris500Sport's Avatar
Member #15279
sorry to bring up an old thread, what washer would this be>
2006 Polaris Sportsman 500 EFI
27X10X12 Mud Bugs on ITP rims
Front&Rear Brushguards
2500# Warn RT
Lock and Ride rear cargo box
EPI clutch kit
60" Moose blade
Old 06-10-2011, 05:34 PM
Member #3491
Sorry - i think dealealer was giving me a line. he really didnt say how he fixed it. he just told me there was a tapered washer on one of the clutches that needed turned over. so i am no help to your question. All i know to this day i have run my machine hard hunting towing wide open and it still runs great. no more squealing and hard shifting.
06 sportsman 800
2010 polaris drive belt adjustment
how to adjust belt deflection on polaris sportsman
how to adjust polaris 800 drive belt
how to adjust polaris sportsman belt tension
polaris 800 xp belt adjustment
polaris sportsman 800 belt deflection
polaris sportsman 800 drive belt
polaris sportsman 800 shifting problems
polaris sportsman belt tension adjustment
sportsman 800 won't shift
why wont my polaris 800 efi sportsman shift win running but fine when its off
Want to "wake" up your 300 Hawkeye/Sportsman? Firehawk ATV Performance Modifications 10 01-21-2014 07:01 PM
2006 Sportsman 700 EFI "dies above idle" NEED HELP ASAP FOR WEEKEND RIDE xlwater Polaris Sportsman 6 12-29-2012 10:59 PM
Sportsman 400 Don't Shut Off "sometimes" polarisjunk Polaris Sportsman 5 01-01-2011 07:32 PM
95 700 Sportsman intermittent pod failure "HELP" bigtodd ATV Repair and Maintenance 3 02-21-2010 06:35 AM
Un "Sportsman" Like Conduct sporthog ATV New Members 1 09-01-2009 01:39 PM
