Old 03-07-2010, 12:49 PM
Rich's Avatar
Member #2532
carb adjustment
hi there I was wondering what the proper setting would be for the clip and needle that goes in the top of the carb when u take the cap off, for altatude level. im at 580ft above sealevel. I have a 300 polaris xplorer.
thanks any help would be great. Rich
Old 03-07-2010, 01:01 PM
if i had a service manual i could tell you...but i dont. but if you call a dealer, they should be able to look that up and give you the factory recommendation if they dont by chance already know it....just a thought
1996 polaris sportsman 500 how to adjust carburetor needle screws
1999 polaris 300 carburetor settings
carburator settings for 1999 polaris explorer
diagram of polaris 300 carburetor
how to adjust a polaris 300 carb
how to adjust carburator 1997 polaris sportsman
how to adjust the carburator on a 300 polaris xplorer
ploaris xplorer 300 needle valve adjustment
polaris 300 carburetor diagram
polaris 500 carb adjustment
polaris 500 carburetor adjustment
polaris atv carburetor adjustment
polaris carb adjustment
polaris carb adjustments
polaris carb settings
polaris carburetor adjustment
polaris carburetor adjustment tool
polaris phoenix carb factory settings adjustment
polaris xplorer 300 carb adjustment
polaris xplorer 300 carburetor adjustment
valve clearance/adjustment ericmichael54 Polaris Sportsman 4 07-18-2010 03:27 PM
chain adjustment shane milstead ATV Repair and Maintenance 7 04-09-2010 02:49 PM
Carb settings needed and Carb issues NolenGerke Polaris Trail Blazer 3 08-26-2009 03:30 PM
carb adjustment help grizzman Polaris Phoenix 2 07-22-2009 08:08 PM
93 Polaris 2X4 Chain adjustment jmccnc ATV Repair and Maintenance 2 05-04-2009 10:50 AM
