01 Sportsman 500ho Losing power intermittantly - Polaris ATV Forum
post #1 of 17 (permalink) Old 10-14-2012, 12:44 PM Thread Starter
fiercecivic's Avatar
Hey there, I am trying to figure out an issue that has just come up recently with my sportsman, any help would be greatly appreciated.
Whats happening is when i start the bike up and ride for the first 3 or 4 minutes everything is good, full power throughout throttle and idles no problem.
It usually starts happening if i am under load eg. mud or steep hill or 3/4+ throttle. The bike will Bog out and be extremely noisy, and it feels like I only have 1/2 the power. It will continue to bog out throughout throttle range until I let the bike idle for a few seconds, then it has full power again and is quiet for another 2 or three minutes then happens again. The bike never actually dies but is very sluggish. I am finding it odd that it does not happen all the time and is corrected by stopping and idling for a bit.
So far I have replaced spark plug, replaced fuel filter, seafoamed the carb and performed a quick check of the camshaft as i have heard that is a common problem.
please help!
fiercecivic is offline
post #2 of 17 (permalink) Old 10-14-2012, 02:07 PM
Clinebo's Avatar
Have you ever changed the fuel filter? It sounds like it might be starving for fuel.
2002 Sportsman 500 HO
Warn 25XT + Bumper
25" Grim Reapers
GoldFinger left hand throttle
and other stuff...
Clinebo is offline
post #3 of 17 (permalink) Old 10-14-2012, 05:56 PM
InRBigness's Avatar
check your air filter and for leaks in the air box. No air equals no power.
08 Sportsman 500HO
01 500HO Plow Machine
InRBigness is offline
post #4 of 17 (permalink) Old 10-14-2012, 06:22 PM
Kevcules's Avatar
It does sound like fuel starvation
You did mention that you changed your fuel filter in your first post.
I have an 01 also.....
Sounds like your float bowl isn't refilling quick enough, maybe some crud at your bowl inlet. How long since you seafoamed the fuel system? If it's a solid material blocking your bowl inlet, seafoam can't eat through it and you may have to disassemble the carb and check it.
It's strange that the bike makes noise when it's acting funny???
I don't think it's the cam because it would always act bad, not just sometimes.
It could be electrical too , where it's intermittent?? I'll be watching this to see what you find.....Good luck
Kevin
2001 Sportsman 500 HO
2006 Honda Rincon 680
Famous saying......" I'm going to the garage" !
Kevcules is offline
post #5 of 17 (permalink) Old 10-15-2012, 03:40 AM Thread Starter
I seafoamed it this past thursday, and left it overnight. Then went riding all day saturday. It was bogging on and off all day. It seems to do it after the bike has been running past 1/2 to 3/4 throttle for more than a minute or two.
I also agree that the cam is out of the question, because it has 100% power most of the time.
What would the symtoms of a contacting ETC be?
Thanks for all the ideas by the way
post #6 of 17 (permalink) Old 10-15-2012, 09:49 AM
PetroMan's Avatar
Check/remove the spark arrester in your exhaust, it maybe restricted. I have had silt from puddles bake on the arrester and plug some of the holes.
What I have owned:
-200M Honda Trike
-95 Polaris Magnum 4 Stroke
-97 400 Sportsman 2 Stroke
-02 500 Sportsman (current)
-02 700 Sportsman
-10 Polaris Razor LE (current)
-12 550 EPS Sportsman (current)
PetroMan is offline
post #7 of 17 (permalink) Old 10-15-2012, 12:46 PM
Kevcules's Avatar
The ETC symtoms are it feels likeit's stumbling , no power etc... Try it in reverse without pressing the button when it's working OK...
Kevin
Kevcules is offline
post #8 of 17 (permalink) Old 10-15-2012, 03:22 PM Thread Starter
I checked the etc contacts, my throttle cable was adjusted properly and they were no where near touching. So i removed the carb, disassembled and cleaned everything. There was no noticeable dirt or buildup on any parts.
I did notice my air box cover was not sitting properly and there was a small amount of water and what looked like clear oil(possibly a bit of sea foam spillover when i fogged the carb) in the bottom of the box. so i cleaned that all out and wiped the air box down. I will reinstall everything this week and give an update if fixed or failed.
post #9 of 17 (permalink) Old 10-15-2012, 03:56 PM
Shellfish's Avatar
My sportsman 400 was doing some what the same thing ran fine on level ground but when climbing up steep long hills it would run out of gas I had to adjust the float In the carb to let alil more gas in the bowl it really woke it up doesn't lay down on me now
Shellfish is offline
post #10 of 17 (permalink) Old 10-22-2012, 03:26 AM Thread Starter
so, after doing all the carb/airbox cleaning. It still cuts out. Anyone have other thoughts?
07 500x2 losing power sunset ATV General Discussion 1 04-12-2012 05:57 PM
Losing power del ATV Repair and Maintenance 11 09-17-2011 09:41 AM
Losing power after a few seconds of WOT. Tony_B ATV Repair and Maintenance 15 04-23-2011 02:40 PM
01' sportsman 500HO losing spark at 1200RPM trickedout ATV Repair and Maintenance 15 03-26-2011 08:18 PM
Losing all power 850xp Rookie Polaris XP 4 03-14-2011 06:18 PM
