01 xplorer 400 2 stroke smoking problems - Polaris ATV Forum
post #1 of 6 (permalink) Old 03-07-2010, 06:47 PM Thread Starter
Wayne0341's Avatar
I have a 2001 xplorer 400 2 stroke im trying to get back running. I had a new top end put in motor, plus i cleaned carb and all jets are clean and atv starts right up. Only problem is it smokes very bad and fouls at least one plug a day. I assume its getting to much oil but not sure. Runs good just fouls plugs, can any one help?
Wayne0341 is offline
post #2 of 6 (permalink) Old 03-07-2010, 07:43 PM
sure does sound like it is getting too much oil, like you said. there should be an adjustment somewhere i the pump i believe
blueline15 is offline
post #3 of 6 (permalink) Old 03-07-2010, 08:12 PM
plowboy's Avatar
Your best bet is to do away with the oil injection. If you dont mind mixing your gas. You can mix it with some of the smokeless oils and pick up power also. I use the amzoil smokeless mixed at 75 to 1 with no smoke.
It is better to remain silent and appear ignorant than to speak and remove all doubt
plowboy is offline
post #4 of 6 (permalink) Old 03-08-2010, 04:27 AM
4getful2's Avatar
They do smoke more until they get warmed up,usually polaris reccomends 40 to 1 upon breakin(about 2 tanks worth) then 50 to 1 . you may want to check to see if the oil pump is set correctly,at idle the lines on the pump and body should line up.
Check counterbalancer oil
Synthetic oils will smoke less.
4getful2 is offline
post #5 of 6 (permalink) Old 03-08-2010, 12:51 PM Thread Starter
Wayne0341's Avatar
Thanks for the help. I am probably going to start mixing gas my self due to the machine is getting up there in age. What is the purpose of the counter balancer on this machine?
post #6 of 6 (permalink) Old 03-08-2010, 01:31 PM
plowboy's Avatar
The counter balance is used to balance the crank . It keeps the engine from vibrating and it also runs the waterpump and oil injection pump.
plowboy is offline
1999 400 xplorer 2 stroke? 1999xplorer ATV Performance Modifications 4 04-08-2010 03:49 AM
2006 Polaris Hawkeye Smoking mrcln1 ATV Repair and Maintenance 2 01-23-2010 11:55 AM
99 xplorer 400 4x4 problems travxplorer99 ATV Repair and Maintenance 0 01-13-2010 12:21 PM
1996 Xplorer 400 2-stroke problems BuckholePoet ATV Repair and Maintenance 6 01-08-2010 03:30 PM
Smoking polaris darrellnell Polaris Sportsman 4 10-08-2009 04:28 AM
