Old 03-09-2010, 05:05 PM
Shane's Avatar
Member #835
Post 95 Magnum 4x4 water in oil
I noticed the coolant level in the resevoir slowly decreasing(over months, occassional use, short periods). checked oil one day, looked funny, green.... Drove it around the next couple of days, 10 minutes at a time tops, noticed it about 1/4 inch below minimum line on coolant resevoir, checked oil stick, obvious water in oil, noticed ticking noise in front left area too. I assume that is not good!
Where to a start? water pump? ....
Old 03-09-2010, 07:00 PM
atvjunkie821's Avatar
Member #2326
could be. If it is you will have to remove the engine and split the crankcases to service the water pump shaft and shaft seals. You best hope it's a head gasket instead!
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
YouTube Channel:www.youtube.com/user/tinkerman01
Old 03-09-2010, 07:45 PM
cam101311's Avatar
Member #2311
Send a message via Yahoo to cam101311
is it running any differently bogging smoking?
1998 polaris 425 magnum 4x4
super swamper vampire tsl
3 inch lift
500 h.o. carb and airbox
plastic fenders and rack swap
relocated radiator
winch
1995 polaris 400 xplorer 4x4 R.I.P
1998 kawasaki 220 bayou
1998 e-ton 90
Old 03-10-2010, 03:58 AM
Shane's Avatar
Member #835
Thanks for the responses.
It runs fine. NO smoke, starts right up.......Had I not noticed the coolant level going down, I would keep running it.
Should I just assume it is the head gasket and replace it? I just ordered the Clymer maintenance manual, do I need anything else. The maintenance mechanic at my school has offered to repair it.
1995 polaris 425 magnum engine oil
1998 polaris sportsman 500 coolant in oil
500 polaris water in oil
95 polaris waterpump seal replacement
antifreeze requirements for polaris 500 magnum
pics of a water pump seal on a 1995 425 magnum polaris
polaris 400 water pump seal pull engine
polaris 425 magnum water pump removal
polaris 500 water in oil
polaris atv /water in oil
polaris atv water in oil
polaris magnum 425 coolant in oil
polaris magnum 425 head gasket
polaris magnum 425 water in oil
polaris magnum 500 water pump
polaris magnum water in oil
ticking noise water in oil
where do you put the oil in a polaris magnum 500 4x4
xtream g05 colant atv
1994 400 Sportsman water in counterbalancer. fishdoktor Polaris Sportsman 1 03-01-2010 09:52 AM
No power after heavy water ridin Jarbo11 Polaris Sportsman 4 09-23-2009 04:07 AM
Ridding in water Fred j 500 ATV New Members 3 06-22-2009 10:17 AM
polaris 500 water pump jpringle ATV General Discussion 2 06-21-2009 05:22 PM
Water Pump Impeller Melted to Mush ?? F-N-G ATV Repair and Maintenance 1 03-25-2009 08:32 PM
