4 Wheel Drive Problems - Polaris ATV Forum
post #1 of 5 (permalink) Old 11-05-2012, 05:31 AM Thread Starter
Steventabor's Avatar
Exclamation 4 Wheel Drive Problems
Hello everyone,
I am seeking help on a 4 wheel drive issue from those guys that know about these things, so if you can help please share. About a month ago I bought a 2007 Polaris Sportsman 800, since then I have had it in for a full service at a certified Polaris dealer. Along with the service several ball joints, bearings and miscellaneous repairs were made. Yet one major issue remains, the 4 wheel drive will not engage. The speedometer works the LCD display shows the 4 wheel drive icon but when in the mud only the rear spins. I can add that the gas gauge does, at times flash displaying random fuel levels.
Thanks guys.
Steventabor is offline
post #2 of 5 (permalink) Old 11-05-2012, 05:50 AM
lost cause's Avatar
There are numerous things that can cause issues with the 4wd on these machines. Speedo not working, voltage at the diff, too little fluid in diff, too much fluid in diff, dirty fluid, wrong fluid, warped armature plate, or broken sprague cage. In that order. Start by checking the speedo, if that works then move down to the diff. to see if you have voltage. If you have voltage, then drain the fluid and ensure you put the proper amount of the Polaris Demand Drive fluid. If that doesn't work then take it apart and look at the sprague cage. If it is cracked or broken, replace it. Also check the armature plate while your in there. It only takes it being warped .005" for it to cause engagement issues.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N AIR FILTER
POLARIS 3500 WINCH
POLARIS OEM BELT
STOCK EXHAUST
lost cause is offline
post #3 of 5 (permalink) Old 11-05-2012, 06:45 AM Thread Starter
Exclamation Follow up
I have a feeling that it is an electrical issue. Originally, the winch wouldn't work when the cooling fan was on and then the issue with the fuel gauge popped up and now I don't have 4 wheel drive, if there are major electrical issues what should I look at in that area? Thanks for your help.
post #4 of 5 (permalink) Old 02-05-2017, 07:16 AM
Krisanne's Avatar
2011 850 xp polaris .....is it possible for cold weather to cause 4x4 issues.
We have been in a cold snap at -15 for a few days. 3 days ago my 4x4 worked. I went out last night the coldest night since I had it and got in a little snag and tried to put the in 4x4.it showed it on the display but didn't actually engage. Any ideas.
Krisanne is offline
post #5 of 5 (permalink) Old 02-06-2017, 09:35 AM
Mac25's Avatar
wow really old thread, try posting here Polaris XP - Polaris ATV Forum
2013 Sportsman 850 HO XP LE
Kenda K587 HTR 28/14s all 4
Mac25 is offline
2000 polaris 500 sportsman ho with 4 wheel drive problems grizzlogger Polaris Sportsman 3 09-29-2012 01:17 PM
scrapping front wheel drive on 2001 325 shaft drive Kiwikiwi Polaris Magnum 3 02-08-2012 09:11 PM
4 wheel drive problems jrous ATV Repair and Maintenance 0 03-13-2011 09:21 AM
01 Scrambler 500 4x4 left front wheel engages when in 2 wheel drive pontiac69 Polaris Scrambler 2 02-15-2011 04:22 AM
Sportsman 400 with four wheel drive problems redzy Polaris Sportsman 3 02-09-2010 07:28 PM
