Old 03-10-2010, 04:30 PM
benm's Avatar
Member #3578
AWD light
I have a 1996 Sportsman 400 4x4 but the AWD light will not come on.
Old 03-10-2010, 06:45 PM
atvjunkie821's Avatar
Member #2326
Transmission switch that is located at the shifter is most likely bad, it feeds the AWD light and the 4x4 coils. You can fix or bypass..
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
YouTube Channel:www.youtube.com/user/tinkerman01
Old 03-11-2010, 05:37 AM
benm's Avatar
Member #3578
thanks,i will check it out.
Old 03-11-2010, 08:27 AM
sshfty1's Avatar
Member #3242
or your light bulb is just burned out like mine was!
Old 03-12-2010, 01:49 PM
benm's Avatar
Member #3578
i ended up pulling apart the gear shift and cleaned it out it was pretty nasty then put it back together and the 4x4 is working good now. still no light but so what. thanks for the help guys.
2000 polaris magnum awd bulb
how check awd coil on atv polaris 330 magnum youtube
polaris 330 magnum awd coil
polaris 4x4 button light bulb
polaris 500 awd light
polaris awd bulb part number
polaris awd bulb replacement
polaris awd light
polaris awd light bulb
polaris awd light bulb part number
polaris awd light not working 98
polaris awd light out
polaris magnum 425 awd light
polaris magnum 425 light bulbs
polaris magnum awd lamp replacement
polaris magnum awd light
polaris sportman awd bulb
polaris sportsman awd light
polaris sportsman awd light fix
polaris sportsman awd switch bulb
3 light mod Outback101 Polaris Sportsman 19 10-08-2010 05:36 AM
Engine light? dodgeram3500 ATV Repair and Maintenance 0 02-15-2010 04:38 AM
awd light ? tlyons68 Polaris Sportsman 3 02-07-2010 04:21 PM
flickering oil light chevyboyiroc Polaris Sportsman 0 02-03-2010 03:45 PM
05 330 magnum no 4x4 but light is on BADD55 ATV Repair and Maintenance 4 12-19-2009 01:23 PM
