Question about sportsman low beam bulb replacement - Polaris ATV Forum
Old 03-12-2010, 07:58 PM
wilb67's Avatar
Member #3612
I have a 1999 sportsman 500. The stock low beam bulb is part #4030059 (27 watt).
Will the higher watt #4030048 37 watt bulb work in it's place? Also, if it will work,why is the lower 27 watt bulb cost more than the 37 watt bulb?
Old 05-11-2010, 09:46 AM
tofast4us10's Avatar
Member #4411
I would love to know the answer to this question as well
Old 05-11-2010, 05:42 PM
wilb67's Avatar
Member #3612
I found this bulb I think will work. you just have to pull the old bulb out of the holder and replace with this one. it also comes in 55 watt and 27 watt. do a searh for this bulb----Whelen H35W12V Halogen Bulb. and it only cost $6.00 !!!!!
Old 05-11-2010, 06:23 PM
big4x4mudder's Avatar
Member #4725
I put a higher watt bulb in some fog lights I had and melted the plastic
Old 05-11-2010, 06:38 PM
wilb67's Avatar
Member #3612
even if you stay with the 27 watt bulb, it's still alot cheaper than the $25.00 polaris wants!!!!
Old 05-30-2010, 11:17 PM
Member #4725
If you steo up the watts a little bit it might be ok the fog lights i melted I jumped from like 55 to 100 watts I had them on an old quad they worked great for about 15 min.
Ride it like you stole it!
94 sportsman 400 SOLD
01 sportsman 400
?? 110 Quadzilla
Old 10-04-2010, 08:19 AM
Max's Avatar
Max Max is offline
Member #7846
I like wilb67 's answer. My 99 Sportsman 500 regularly burns out both of the low beam bulbs and I am looking for options. Tired of spending $50 to replace them every year I'll check out Whelen's bulbs. Any thought on the HID lights?
Old 10-04-2010, 08:24 AM
Max's Avatar
Max Max is offline
Member #7846
I am also considering replacing the entire low beam assemblies with a set of lights from an auto supply store. Replacement bulbs are available at any Wal Mart for $6. I just don't know if the electrical system will handle the change.
Old 10-26-2011, 04:51 PM
dannis1950's Avatar
Member #19941
Whelen makes a H27W12V bulb.
Old 10-27-2011, 06:59 AM
Member #4411
I tried it a while back never could get it to work, I just gave up both of my low beams have been burned out for about a year. I only use high now
2001 polaris sportsman burnt out light bulb
2001 sportsman 500 27w 12v bulb
2009 sportsman 500 bulbs at walmart
4030059 bulb
4030059 bulb cross reference
bulb cross reference 4030059
polaris 4030059
polaris 4030059 bulb cross reference
polaris 4030059 replacement
polaris low beam replacement bulbs
polaris sportsman 500 low beam bulbs
2001 Sportsman Starter Replacement dodgeboy528 ATV Repair and Maintenance 3 09-03-2013 05:26 PM
WTB head light bulb and ring bomberboat ATV Parts for Sale 1 01-07-2010 02:53 AM
Bendix replacement, 700 Sportsman yamtz ATV Repair and Maintenance 1 11-16-2009 06:51 PM
2004 Sportsman A-arm Replacement fmongeau ATV Repair and Maintenance 1 11-01-2009 09:01 AM
Replacement boots for an 08 sportsman 800 Idaho 800 Polaris Sportsman 9 10-08-2009 08:55 PM
