Old 03-13-2010, 09:40 AM
model70's Avatar
Member #3435
2005 sportsman 500 oil change ?
so feel kinda dump asking this question but i just got the quad and am going to change the oil but dont quite understand the whole oil tank and pump thing not sure about when you have to prime it and when you dont if i just dump the oil in the tank and fill it back up do i have to prime the pump still or are you ok then.are these the same as the 98 sportsman 500. the manual seems to make it a little more complicated then it is or is it acually that complicated...i dont want to screw anything up...thanks..
2006 polaris sportsman 500 HO EFI
Old 03-13-2010, 01:12 PM
first, what i am about to say is my personal opinion. i have never had any problems changing the oil in this way, but "my way" kinda scares most people away.
not a dumb question at all, lots of people get confused. basically yes, the 98 and 05 sportsman are going to have the same procedure. with the 4-stroke it is really not neccessary to prime the oil pump like you would want to on a 2 stroke. just like the guys at the quick lube dont prime your oil pump on your 4-stroke car.
now, so we have a dry sump system on both machines. when you pull the plug out of the reservoir tank, you will get most, but not all of the oil. there still will be a small bit of oil in the crankcase. there are drain bolts on the right side of the machine that drain that last of the oil out of the crank, but they are a pain in the ass to get to. what i do, and this is the part that freaks people out, is after letting the reservoir tank drain, i turn the machine on, with the plug still out. as the machine cranks over and starts up, the oil pump pushes that last bit of oil in the crankcase out through the reservoir tank. when the machine is running, you watch the oil plug. oil with start pouring out as soon as the engine starts to crank and fires up. THE ENGINE RUNS FOR ONLY ABOUT 7-10 SECONDS. as soon as the oil starts to turn into a dribble, you shut the machine back off. now all the oil is out. just change your oil filter, put the plug back in, and fill her back up.
now, i have had a discussion with mechanics about this. this process was actually explained to me by a mechanic. and if you think about it, running the machine with almost no engine oil in it for a few seconds is no worse then when you first start up your machine with no oil pressure. either way it takes 10-15 seconds to build oil pressure up after you start, and changing the oil this way the engine runs for even less time then that.
now with that said, you can do serious damage to your engine, so be careful. but its pretty clear when to shut the machine off if you go this route.
Old 03-13-2010, 01:24 PM
Spitfire79's Avatar
Member #3532
The problem with doing it that way is that once you put the oil in the resevoir, the engine will again run dry until the pump primes the system. There is more wear on initial start up like this then there is in several hours riding. The slight amount left in the case is minor compared to the amount of fresh oil. I would rather change oil more frequently than run without oil. Also remember to fill the new filter when changing.
Jeff
Old 03-13-2010, 04:51 PM
this is true, but we are talking a few seconds here before the system is primed again. like i said, not many people agree doing it this way, thats fine, i understand. i know a guy who has been doing this on his older polaris every oil change and has over 3,000 hours on it, never been rebuilt.
2005 polaris 500 oil capacity
2005 polaris sportsman 400 oil change
2005 polaris sportsman 500 oil
2005 polaris sportsman 500 oil change
2005 polaris sportsman oil change
2005 sportsman 500 oil capacity
2006 polaris sportsman 500 oil change
2006 polaris sportsman 500 oil filter
98 polaris sportsman 500 oil change
how do u change the oil in a polaris sportsman 500
how do you change the oil in a polaris sportsman 500. 2005
how to change oil on 2005 polaris
oil change in a 2005 polaris atv
oil change on 2006 polaris sportsman 500 ho
oil for 2005 polaris sportsman 500
polaris 500 sportsman oil change
polaris oil change on 2005 sportsmen
polaris2005 sportsman 500 oil filt
sportsman 500 2005 oil change
'09 Sportsman XP Tire Change Pinochle767 ATV Wheels & Tires 101 04-01-2010 07:06 PM
2006 sportsman oil change pondfishr ATV Repair and Maintenance 5 01-24-2010 01:30 PM
08 Sportsman 500 oil change??? kdsberman ATV General Discussion 11 12-20-2009 06:03 AM
Simply Oil Change ? 2006 Sportsman 700 t2timmy ATV Repair and Maintenance 13 10-07-2009 07:22 PM
Oil & Filter change 500 Sportsman 08 newrider ATV General Discussion 4 10-01-2009 05:50 PM
