03-14-2010, 09:09 AM
Member #3629
2004 ATP 500 HO 4x4/elec. issue
Hello All!
Can anyone help? I have a 04 ATP that won't activate the AWD. The first thing I noticed was the cluster no longer indicated the gear in. Rest of cluster is fine. Also unit would not go into diagnostic mode. Here's the puzzle to me, If I (using a test light) ground out the drum switch/gear position switch I then get the cluster indicator to reflect a gear which thus engages the AWD. With that said, where is my problem? Where would the Drum switch normally get it's ground from and how do i fix?
Thanks all. Look forward to visiting often.
03-14-2010, 09:39 AM
Member #2326
The gear selector switch for the transmission maybe faulty
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
YouTube Channel: www.youtube.com/user/tinkerman01
03-14-2010, 11:39 AM
Member #3629
Is there a way to test it?
03-14-2010, 03:10 PM
Member #3641
look at the connector on the rear left side of your transmission, there may be 4 or 6 wires either the brown or your black wire is the ground, splice and ground out to the frame see if that helps. if not call your polaris dealership and ask if there is a recall on your computer/ECM there was plenty recalled on 2004 models it may have something to do with it.
03-15-2010, 08:05 AM
Member #3629
ManitobaHemi....You were/are correct. The ground is in-fact the brown however grounding it had no affect. On the other hand, splicing a ground to any of the other wires (I chose the H gear which is the blue/red) gave me a "H" gear indicator on the cluster which in turn allowed the AWD to function normally. The only drew back was/is the cluster indicator regardless of gear in always reads "H". In close, if I need the cluster to tell me what gear I'm in, I need alot more help then you guys can provide.
THANK YOU ALL FOR HELPING. LOVE THIS SITE!
04 atp 500 manuel, 2004 atp 500 ecm recals, 2004 polaris 500 atp problems, 2004 polaris 500 ho ecm, 2004 polaris atp 330 transmission, 2004 polaris atp 500 4x4, 2004 polaris atp 500 4x4 problems, 2004 polaris atp 500 ecm, 2004 polaris atp 500 ho, 2004 polaris atp 500 ho 4x4 not engaging, 2004 polaris atp 5oo 4x4 h.o. recalls, 2004 polaris magnum 330 atv troubleshooting awd, 2004 polaris sportsman 500 4x4 not working, 2004 polaris sportsman 500 ho 4x4, 2004polaris atp troubleshooting, 500 polaris sector gear positioning, ecm for 2004 polaris atp 500 ho, fuse box for polaris atp 500 2004 model, parts diagram for 2004 polaris 4x4 atp no 4wheel drive, polaris atp 500 trouble shooting speed cluster
