2002 Sportsman 500 Drive shaft removal u-joint - Polaris ATV Forum
Old 01-03-2013, 08:37 AM
Texas251's Avatar
Member #22013
I really appreciate this forum. There is some great information on it.
I have a 2002 Sportsman 500 with the independant suspension rear end and need to replace the u joint on the main shaft. What is the easiest way to remove the drive shaft and do you know the NAPA part number for a new one with a grease insert.
Thanks in advance..
Old 01-03-2013, 05:11 PM
Kevcules's Avatar
Member #14887
I have a 2001 so I think our bikes are similar.
You have to drive out the large roll pin from the front u-joint , then the shaft should slide off the rear spline.
You can check prices at cyclepartswarehouse dot com for OEM polaris parts.
Kevin
2001 Sportsman 500 HO
2006 Honda Rincon 680
Famous saying......" I'm going to the garage" !
Old 01-04-2013, 05:17 AM
You also have to take 4 bolts out of rear diff and slide it back a little , napa#338 for u-joint
Old 01-04-2013, 07:19 AM
Kevcules's Avatar
Member #14887
For some reason I didn't have to do that when I removed my shaft assembly?
Kevin
Old 01-05-2013, 04:15 AM
OOps my bad Im thinking of the 6-7-800s 338 u-joint will still work.
2001 polaris sportsman 500 ho front driveshaft removel
2002 polaris sportsman 500ho front drive
97 polaris sportsman rear shaft removal
changing u-joint 2002 polaris 700 sportsman
how to remove front drive shaft polaris sportsman 500
how to replace rearvu joints on polaris sportsman
how to replace ujoints in driveshaft going to front end on a 500polafis sportsman 2002
howtotakefrontshaft2002polarissportsman500
polaris sportsman 500 front drive shaft
remove rear drive shaft polaris sportsman
replacing u joint on polaris 500 sportsman
sportsman u joint removal
1997 Sportsman 500 rear drive shaft removal BDL ATV Repair and Maintenance 5 03-02-2015 09:53 AM
Front prop shaft and u-joint removal Carny ATV Repair and Maintenance 2 08-05-2012 06:13 AM
2002 sportsman 500 rear half shaft removal from axle. Hmm... redneckff42 ATV Repair and Maintenance 4 04-02-2012 04:15 AM
2002 Sportsman 700 rear drive shaft removal pbm1957 ATV Repair and Maintenance 5 01-20-2011 09:49 AM
u-joint in rear pro shaft[drive shaft] two as one ATV Repair and Maintenance 3 10-21-2009 08:43 PM
