4wd problems - Polaris ATV Forum
Old 01-29-2013, 08:23 AM
huntin4rax's Avatar
Member #33771
4wd problems
Need some help! I have a 2008 sportsman 800 efi and this morning I was clearing my driveway of snow and the 4wd wouldn't work correctly. When it did engage it was at a higher RPM and would clank when it engaged but would only stay engaged for a short time. 95% of the time it did not work at all. Didn't matter if i hit the override button or had it in ADC or 4x4. Any ideas?
Old 01-29-2013, 08:29 AM
Old 01-29-2013, 08:48 AM
MustBeNice's Avatar
Member #29059
Hello & Welcome
The rule of thumb would be.... Start by changing the front differencial fluid (a couple of times to clean out all dirty fluid, try use briefly between changes) as dirty fluid is usually the cause of intermitant AWD issues. Note: Use ONLY Polaris demand drive fluid!! One bottle should get you 2-3 front diff. fluid changes. If this doesn't work it may be a differencial internal issue.
Remember, the AWD only kicks on when the rear wheels slip/loose traction, and is not "engaged" at all times. Very similar to the "Auto 4x4" in a Ford or GM truck/suv.
West Fargo.... How much snow did you guys get? We got about 7"-8" down in Fergus Falls area. Like the user name "Hunting for Racks"!! Is that the Antlered whitetail 4 legged type or the 2 legged human female type.... or both??
Matthew "MustBeNice"
Mods: Polaris 2500HD Winch - Synthetic Rope - MotoAlliance Line Stopper - Glacier3 60" Plow - Polaris Rack Extenders - Polaris Bumpers - LowPro Shield - Polaris Hand Guards - Warning Debadge - 3Way Head Light (Relay) - Cabelas Mirrors - Wes Ind. Std Seat/Box - Kolpin Fuel Pack Jr - 26" ITP MudLite Tires - HighLifter HD Springs - MotoAlliance Sirius 6" Pro LED Light Bar
Old 01-29-2013, 11:16 AM
huntin4rax's Avatar
Member #33771
We got 5 - 6 inches here. With the ice we got before the snow my back tires where spinning constantly and the front wouldn't engage. Like I said the couple times it did engage it really clanked.
PS - always looking for the antlered kind. The wife wouldn't appreciate me looking for the "other" racks.
Old 01-29-2013, 11:47 AM
MustBeNice's Avatar
Member #29059
If it is still engaging from time to time..... I'd start with the fluid changes and hope for the best!! This would be the simplest and cheapest attempt to fix the problem. And it seems to be the most common issue with the AWD, unless an internal component failed/broke. If it doesn't, you at least ruled it out and know you need to dive in deeper. It'd also be good maintinance for a 2008, if it hasn't been done yet.
Question(s), How many miles & hours are on your machine? Ever see any water or mud submertion?
Sorry, didn't know your marital status..... that's why I asked for clarification. I don't think any significant other appreciates that, unless she's lookin' too!!
Old 01-29-2013, 11:51 AM
huntin4rax's Avatar
Member #33771
Thanks so much for your help! I will try that tonight and let you know the result! 150 hours - 1100 miles. I have a look but don't even think about touching marital agreement!!!! LOL Have a good one!
Old 01-29-2013, 12:30 PM
MustBeNice's Avatar
Member #29059
Hope it works.....let us know!! May want to ask a mechanic over at "Wheels Inc." when you get your fluid, just to verify he thinks your symptoms match this remidy!
Have you ever changed the front diff. fluid? How long have you owned the machine?
Old 01-29-2013, 12:33 PM
huntin4rax's Avatar
Member #33771
Only had it a few months. Never changed the front diff. fluid before but I am about to search the internet for a tutorial. I am a farm boy, should be able to figure it out!
Old 01-30-2013, 08:16 AM
huntin4rax's Avatar
Member #33771
Change the diff. fluid. Didn't fix the problem. Road it a little last night and it didn't even engage the 4wd at all. spun the back tires trying to get the front to engage...no luck! What should I try next?
Old 01-30-2013, 08:42 AM
MustBeNice's Avatar
Member #29059
Just to verify.... AWD switch is "on" and "AWD icon" light is illuminated on dash display? If so, and the fluid change didn't fix the problem..... I'd guess it to be a hilliard or armature issue in the front differncial.
Need a link to a service manual? There are a few links on here to pdf versions on private hosted sites......
08 sportsman 4 wd problems
2005 polaris sportsman 400 no awd icon on dash
2006 polaris ranger awd light dosent work
2012 polaris ranger 500 4 wd differental replacement
polaris 440 4wd trouble
polaris 4wd problems
polaris atv 4wd problems
polaris brutus 4 wd problems
polaris ranger 4wd faults
polaris sportsman 4wd doesnt work
polaris sportsman 500 kicking out of 4wd at high rpms
troubleshoot polaris atv 4wd
Battery Problems/HID Problems BowHuntingSportsman500 ATV Repair and Maintenance 4 01-06-2013 06:18 PM
500 HO problems Jmathey9 ATV Repair and Maintenance 9 10-10-2012 06:28 PM
850 problems jma3082 ATV Repair and Maintenance 5 09-30-2012 05:20 AM
Problems MCRAD ATV General Discussion 1 11-02-2011 06:01 AM
4x4 problems srambler244 ATV Repair and Maintenance 1 01-24-2011 05:37 PM
