oil fill tube - Polaris ATV Forum
post #1 of 4 (permalink) Old 02-02-2013, 04:43 AM Thread Starter
polarisg's Avatar
oil fill tube
I have a 2009 polaris sportsman 800 EFI and I noticed some air blowing out of the oil fill tube, anyone know what causes this. Thanks
polarisg is offline
post #2 of 4 (permalink) Old 02-02-2013, 04:57 AM
MustBeNice's Avatar
Assuming it was running while you pulledbthe dip stick.... this would be caused by the piston's motion. When running the bottom side if the engine works like an air pump so to speak, this is why the crank case is vented, to allow this air preasure to escape. If it is an over excessive amount of air you could have a little blow by and eventually a rebuild (new rings) will be in order. But some should be expected. I wouldn't recommend pulling the dip stick to check or add oil when running.
Matthew "MustBeNice"
MustBeNice is offline
post #3 of 4 (permalink) Old 02-02-2013, 05:04 AM Thread Starter
polarisg's Avatar
Thanks for your inpu, I have a 500 and it isnt blowing nearly like the 800, the 800 is not only blowing air but it seems loud vs the 500
polarisg is offline
post #4 of 4 (permalink) Old 02-02-2013, 05:07 AM
bgirard420's Avatar
Have to agree, don't open the fill cap with the engine running. If it has oil coming out with the engine off, then it's time for a new cap/dipstick.
2013 Polaris XP 850 HO LE EPS
2010 Polaris 500 HO
bgirard420 is offline
Radiator Fill Throat? Paperboy1 Polaris Sportsman 2 02-26-2012 08:01 AM
Fill front hub with oil? 99xjjoe Polaris Scrambler 6 04-12-2011 06:43 PM
95 Xplorer 400 hub fill port Thor2911 ATV Repair and Maintenance 0 03-20-2011 03:20 PM
Whats the best thing to use to fill oil? bama13 ATV Repair and Maintenance 2 04-17-2010 01:42 PM
