plow and winch stuck on Sportsman 550 - Page 2 - Polaris ATV Forum
  #11 (permalink)
Old 02-07-2013, 01:49 PM
HowdysMom's Avatar
Member #28135
winch/plow problem
I turned the knob as far as it would go, pulled on the orange rope and nothing happened. I guess it doesn't freespool!
  #12 (permalink)
Old 02-07-2013, 01:52 PM
HowdysMom's Avatar
Member #28135
Originally Posted by Lollygagger77 View Post
it is a round turn nob on the right side of the winch (as your looking at it from the front of the machine) I think you turn it down to release and then back up to re-engage..
No luck. I turned the knob., pulled the orange tag....nothing happened. I guess it doesn't freespool!
  #13 (permalink)
Old 02-07-2013, 01:56 PM
skizmo's Avatar
Member #13773
if you have that nob there that is the freespool.. what winch do you have..
ok if the rope went back on it self and you spooled it in using your controls,it may be wrapped over it self..If you can get some one to operate the control wile your pulling on the rope it may help..get them to go in and out on the contriol and see if you get it to let go and start to free spool out.
2011 550XP CAMO
  #14 (permalink)
Old 02-07-2013, 02:10 PM
HowdysMom's Avatar
Member #28135
Should it be in free spool mode when doing this?
  #15 (permalink)
Old 02-07-2013, 02:39 PM
skizmo's Avatar
Member #13773
[quote=HowdysMom;266499][quote=skizmo;266494]
Sorry bout that...No if the nob is set to free spool the handle bar control will not work the winch...Put the nob back to normal operation (winch NOT free spool) and just try to play with the controls wile you have tension on the rope (pulling out)..
2011 550XP CAMO
  #16 (permalink)
Old 02-07-2013, 03:03 PM
HowdysMom's Avatar
Member #28135
[quote=skizmo;266511][quote=HowdysMom;266499]
Sorry bout that...No if the nob is set to free spool the handle bar control will not work the winch..Put the nob back to normal operation (winch NOT free spool) and just try to play with the controls wile you have tension on the rope (pulling out)..
GOT IT! Thanks...I'll give it a go tomorrow. Sick of thinking about it tonight!
  #17 (permalink)
Old 02-07-2013, 03:06 PM
waynev's Avatar
Member #6512
might be your contactor for the winch a little corrosion in it and it will act up mine did this i took it apart and cleaned the contacts and worked better. eventually had to replace the contactor though
2010 Sportsman 850 XP EPS Stealth Black
Glacier II Plow System with plow strap
3500HD Polaris Winch w/ synthetic rope
2010 Sportsman 550 XP EPS Crimson Red, Rear Seat
  #18 (permalink)
Old 02-07-2013, 04:26 PM
MrQuadman's Avatar
Member #32353
i couldn't pull on mine hard enough, by hand, to free it from being jammed but reversing with it in freespool mode worked good,
just needs a good hard yank!!... but be nice to it
2012 500 sportsman
heat demon grips
glacier III plow
rear rack extender
26" zillas on itp delta steels
ice screws in stockers for plowing
modded rear rack seat+storage
2x camo rotopax 1 gal up front
ram mount gyro bevy holder
  #19 (permalink)
Old 02-07-2013, 04:33 PM
polaris_nut's Avatar
Member #32423
Think about switching to the synthetic rope...
2013 Sportsman 500HO Red
L&R Rear Box
Symtec Hand and Thumb warmers
Pure Polaris Quick Release Windshield
Pure Polaris Mirrors
2500lb Polaris Winch
Frt & RR Pure Polaris Brush Guards
Oregon 550t
Wired for Gerbing heated gear, socks, pants, & jacket
4 gal Kolpin Fuel Pack
UNI air filter
3 headlight mod
winch fairlead protector
Wife's
Exactly the same only White
atv plow stuck
atv winch sticks in the down position when plowing snow
freespooling polaris sportsman winch
my warn winch on my wheeler goes up but not down
plow winch stuck
polaris troubleshooting attached plow is stuck
polaris winch free spool knob
polaris winch plow stuck in up position
polaris winch stuck
stuck atv plow winch
used 2010 polaris 550 with winch and plow
winch to my plow is jammed in my 4 wheeler
Winch and plow help Spectre06 ATV General Discussion 9 09-08-2012 07:57 PM
2011 polaris sportsman 500 plow and winch mount help!! CarFanatic Polaris Sportsman 13 05-26-2012 05:51 AM
please help. snow is coming and need atv to plow. rear brake cylinder stuck bsts7707 ATV Brakes & Suspension 1 01-19-2012 09:10 PM
Stuck between glacier III and warn plow spellicy Polaris Sportsman 8 12-04-2011 09:05 PM
*for sale best offer* green sportsman 700 4x4 winch plow combo super trapp boostedradial ATVs For Sale 3 01-11-2011 10:09 PM
