Ok. Where do I start......
I was riding on ice, AWD stopped working. Then on my way back to the truck, I got stuc......submerged. Anyway..... I drained EVERYTHING and got it running again....but again, the AWD wouldn't work. So.....here's my situation. NOTE: THE AWD DID NOT STOP BECAUSE IT WAS SUBMERGED..........IT STOPPED LONG BEFORE I WENT UNDER WATER SO PLEASE DON'T POINT OUT "WATER IN THE DIFFERENTIAL" AS A POSSIBLE ISSUE.
1. AWD wont engage.
2. The instrument / speedo works.
3. The AWD switch is brand new (broke the thumb throttle on a different adventure)
4. Pulled the front differential and rebuild it with new cage / armature plate / bearings / seals.
5. Tested the armature plate with the side of the differential in my hand, connected to the ATV with the engine running / AWD switch "on" / and in gear....yes...high gear...not reverse (cause I know someone will be stupid enough to point out if it was in reverse you have to push the override button....)
6. I have tested the gearcase coil resistance and voltage.
Everything works fine........up there.
I'm thinking its a problem in the Transmission. Does anyone know if there is a sensor or something in the trans that would cause the front not to work. Basically, the front would turn if there were something turning the drive shaft going up there......
Still stuck :nixweiss:
1. AWD wont engage.
