Old 03-27-2010, 04:22 AM
alleskovar's Avatar
Member #3033
Question 07 Outlaw Rear Hub Freeplay issue. HELP
07' Outlaw 500 IRS
How much freeplay is my center rear hub suppose to have if any? I am waiting on a new sprocket and noticed a loose rear hub. I have a manual for the quad but could not find anything referring to this issue. I would also like to know how I can find out if this quad has been serviced for the recall on it.
Old 06-26-2010, 05:18 AM
alleskovar's Avatar
Member #3033
No help or thanks to this board.....
Is anyone out here? I have torn the hub apart after hearing a bearing loose.....the hub should have no freeplay and was easy to replace the bearings after the pulling apart of the hub. The hub also needed to be pressed back together. IT was an easy job. If anyone has any questions...or is even out there.....Ill be glad to help......
Old 06-26-2010, 05:49 AM
SLxp550's Avatar
Member #4836
lol, gotah give some time for reply post my man. yes you are correct should be no visible play. as for the recall get the vin# and contact your local dealer to look it up.
2010 550xp
Mossy Oak camo
3500 synthetic Polaris winch
front & rear delux brush guards
Front storage box
When in doubt.......Throttle Out.
Old 06-26-2010, 08:26 AM
alleskovar's Avatar
Member #3033
I posted in February .......
And made the second reply todaY 6-26-2010....... How long should I wait...Thanks....
Old 08-09-2010, 03:07 PM
zeyn's Avatar
Member #6430
How did you split and put hub back together , Say you need a special tool in manaul which i can not find anywhere.
Old 08-09-2010, 05:11 PM
alleskovar's Avatar
Member #3033
Splitting the hub.....
If you break it down that far.... the local dealer has a tool to do it or if you know someone that works at a machine shop or auto shop they should have some sort of bearing press that would work. The local dealer offered to do it for free.
Im rippin again like new!!!!http://www.polarisatvforums.com/foru...1&d=1281403359
Tags
freeplayin rear hub, loose rear hub, outlaw irs rear hub
06 outlaw 500 rear wheel hub
06 outlaw 500 recall
06 outlaw 500 wheel bearing replacement
06 polaris outlaw rear hub bearings
06 polaris outlaw rear wheel bearing loose
outlaw 500 loose rear hubs
outlaw 500 rear hub loose
polaeis outlaw irs sprocket hub
polaris outlaw 500 rear housing removal
polaris outlaw 500 rear sprocket hub
polaris outlaw irs rear hub bearings
polaris outlaw loose rear
polaris outlaw rear bearing
polaris outlaw rear housing
polaris outlaw service manual
polaris outlaw specialty tools
quad sprocket hub freeplay fix
rear hub tool for polaris outlaw irs
rear wheel slop polaris outlaw irs
why is the play in my sprocket on my 06 polaris outlaw irs
Outlaw rear housing atverrob@yahoo.com Polaris Outlaw 8 08-14-2011 11:08 AM
2004 TrailBlazer Rear Brake Issue lpujml1 Polaris Trail Blazer 9 04-26-2010 05:28 PM
A site issue or IE browser issue? tech geeks look here! blueline15 Site Issues & Suggestions 15 03-31-2010 01:58 PM
Sportsman 800 rear lower arm issue... rotaxdave1 Polaris Sportsman 5 01-27-2010 04:10 PM
Outlaw rear housing atverrob@yahoo.com ATV New Members 3 06-21-2009 04:44 PM
