Old 03-28-2010, 11:13 AM
zman57's Avatar
Member #3924
2008 Polaris 500 EFI Oil Change ???
I hate the thoughts of sounding stupid; however I am new to ATVs and I am trying to work my way through changing the oil in my 500 sporstaman EFI. I am not new to mechanics but this is really frustrating me!!
Where is the crankcase plug at ? The owners manual tells me to drain the crankcase while doing the oil change, does anyone have a pic of it?
Priming the oil pump after I change the oil. The oil kit that I purchased from the dealer does not say anything about priming the pump, but the owners manual does, since I removed the lower hose to clean the screen I am assuming that I need to prime the system.
I cannot find the pressure relief slit as shown in the owners manual on the upper hose. How do you know when the pump is primed ???
Your help and advice will be appreciated on this
Thanks Zman
Old 03-28-2010, 11:25 AM
The Kid's Avatar
Member #3743
i drain my tank and case then put new oil in and go, no need to prime pump. the drain is on the right side of the motor under the pull rope housing on the side not bottom
The Kid
heel clicker
Warn 2500 puller outter
SS108's
29.5's Laws skinny/fat
rubber down custom intake
homemade exhaust snorkel
rad. relocated up top
chains on front & rear A arms
swaybar removed
Old 03-28-2010, 11:39 AM
zman57's Avatar
Member #3924
Thanks Kid, I just came back in from the garage and I just found it, and you confirmed it for me.
I appreciate the response!!!
2008 polaris atv oil specs
2008 polaris sportsman 500 oil change
2008 polaris sportsman 500 oil filter
change oil in ranger polaris
how do i change the oil in a 2010 500 polaris ranger
how to change oil in polaris ranger 500
how to change oil on polaris ranger 500
how to change oil on polaris ranger 500 efi
how to change the oil on a polaris ranger 500 efi
i put 10/30 in polaris 500
oil change kit for 2009 polaris ranger 500 efi
oil change on 2011 polaris ranger 500efi
oil change polaris 500 ranger
oil filter for 2008 polaris sportsman 500
oil is low after chanigin oil on my ranger 500 efi
polaris ranger 500 efi oil change
polaris ranger 500 oil capacity
polaris ranger 500 oil change
polaris rzr coolant type
repair manual for 2008 polaris ranger 500
2008 Polaris Sportsman 800 EFI Overheating farmer7 ATV Repair and Maintenance 22 10-30-2011 11:01 AM
Flashing Wrench 2008 Polaris 500 efi ho hoythunter02 Polaris Sportsman 8 04-14-2010 05:29 AM
2008 polaris 500 h.o idle rpm??? ge_morgan ATV General Discussion 3 03-05-2010 04:42 AM
2001 polaris sportsman 500 ho oil change question CrazyFazy Polaris Sportsman 1 01-27-2010 09:18 AM
2008 Polaris 525 IRS winger27 ATVs For Sale 2 07-10-2009 12:24 AM
