Gear selector doesnt seem to be moving gear, rear locked - Polaris ATV Forum
post #1 of 11 (permalink) Old 03-17-2013, 04:08 AM Thread Starter
mathewdylang's Avatar
I bought a Polaris xplorer 500 yesterday that "had Carb trouble". Got there and seems to just need needle and bowl. But guy jump started the quad and it ran as well as it could with fuel leaking. Soon as it started it wanted to move backwards. So I jumped on it to hold the brake while they disconnected the jumper cable so I could back it into the truck. After hitting the throttle it wouldn't move. So I tried to move the shifter and it would "move" but wouldn't stay in any position I moved it to. We killed it and decided just to push load it (it had rolled freely before starting) only to find rear wheels will not turn like in gear? Has anyone ever had this problem? I know its his word but he stated when parked last summer all gears worked, just parked it because the leaking fuel. With it trying to move backwards on start up I didn't figure it was a stuck pulley. Possibly between gears?
mathewdylang is offline
post #2 of 11 (permalink) Old 03-17-2013, 04:19 AM
goesreallyfast's Avatar
I had this problem with my 500. The nut holding the shift linkage to the bar on the transmission that shifts it was loose so there was enough play in it that it would not shift. I think the rear tires are locked because it is in gear.
2012 Polaris Sportsman 850 HO Muddified
2010 Polaris Sportsman 850 Touring EPS Muddified
2001 Kawasaki Bayou 220
1999 Polaris Sportsman 500
goesreallyfast is offline
post #3 of 11 (permalink) Old 03-17-2013, 04:22 AM Thread Starter
Thanks I will look into that. My friends dad has it in his garage looking it over since he rebuilds all kinds of bikes. I will bring that up when I go over later.
post #4 of 11 (permalink) Old 03-17-2013, 05:00 AM
Bruce! is offline
post #5 of 11 (permalink) Old 03-21-2013, 09:00 PM Thread Starter
Well we unhooked the shift linkage to the high low selector. The shifter moves smoothly into all 3 normal gears, the back wheels move freely, and when its started and put in gear it goes no where. In f n and r it free spins the belt like in neutral. Is it because we have the high low linkage off? The only thing I could think of is the high low is stuck in neutral now that we have the linkage off like neutral on a truck transfercase? Anyone got an idea?
post #6 of 11 (permalink) Old 03-22-2013, 10:30 AM Thread Starter
Can anyone tell me which linkage goes to low and which controls f n and r? I pulled both off and got the shifter to move freely now. But I don't remember which on goes where on the shifter end.
post #7 of 11 (permalink) Old 03-22-2013, 10:58 AM Thread Starter
Nevermind I found it in the manual. It shifts neutral and forward. Will pull back in reverse, and move forward to low, but won't stay in those gears.
Also looking at the manual it says my transmission takes 10w-30 motor oil??? 20fl oz. Is this right? I mean I know its THE Polaris manual but I thought it had to have special gear lube.
post #8 of 11 (permalink) Old 03-22-2013, 03:51 PM
tt425's Avatar
It don't take a special type of fluid. Those shifter rods have to be scyronized to work together so that they don't bind up. So you will have to do some fine tuning in adjusting the linkage. Sometimes it is a pain. Make sure the idle is not set to high or it will grind gears when shifting.
Maybe that info will help you some.
tt425 is offline
post #9 of 11 (permalink) Old 03-22-2013, 05:45 PM Thread Starter
Well I haven't tried shifting while its running still waiting on needle and seat. But I'm going to change tranny fluid with 10w-30 synthetic tomorrow and change the engine oil. See if I can get it to run enough to move the gears with it running see if it shifts running or not.
post #10 of 11 (permalink) Old 03-23-2013, 10:14 AM Thread Starter
Can I use amsoil 10-30 in the transmission and shifter box?
Moving in Gear maverick11 ATV General Discussion 7 01-31-2013 05:56 AM
Gear Selector Loffmar77 ATV General Discussion 4 05-25-2012 08:38 AM
Gear selector won't come out of neutral panfishpat ATV Repair and Maintenance 5 02-13-2012 11:45 AM
Gear selector jkoons ATV Repair and Maintenance 1 06-23-2010 12:09 PM
gear selector Craezy Polaris Sportsman 1 08-07-2009 08:50 AM
