03-30-2010, 09:37 PM
Member #3979
boggs under throttle
My sportsman 400 starts and idles good but bogs and backfires when i give it throttle. started doing it suddenly last fall as i was using it. tried carb cleaner and didn't seem to help so just parked it overwinter and now started fine again but same problem. any ideas?
03-31-2010, 04:39 AM
the carb probably needs a good ole' fashion tear down and clean
03-31-2010, 05:13 AM
Member #3979
Does that make sense that it would start / idle / run at 15 mph nice?
03-31-2010, 09:38 AM
Member #3621
The pilot jet allows your bike to idle and provides fuel up to 1/4 throttle. That's probably fine but maybe your main jet is clogged.
2006 Polaris Sportsman 450 4x4 - Winch, Plow, Backseat
03-31-2010, 10:11 AM
Member #3330
My Daughters Bayou did the same thing when we bought it. I tore down the carb and used speaker wire strands to clean all the jets out. Put it back together and better but not right. Tore it down again and missed a jet. Now it runs great.
Craig and Paula
OP KS\Truman Lake MO
97 400 Sport (Hornet)
87 250 Trailboss (Devil)
03 Kaw 250 Bayou (Tonka)
86 Suzuki lt230ge (Blacky)
03-31-2010, 02:08 PM
agree
agree...
you have mulitple jets for different portions of how wide the throttle is open
....so that easily could be a problem
03-31-2010, 03:25 PM
Member #3979
Thanks for the info. will give that a try before bringing it in and letting them replace camshaft like they talked of. worn cam didn't make sense to me as it started suddenly.  Any tips on how to go about carb teardown???
03-31-2010, 04:54 PM
Member #1234
what year is this machine??
03-31-2010, 04:58 PM
Member #3979
not even sure...04? is there a easy way to check?
04-09-2010, 07:53 AM
Member #3871
there is a serial number etched into the frame right behind the left a-arm..should start with a .......4xa...if you get that big long number ..call me @ 1-877-haydens..and i can punch it into polaris' website and let ya know what yr it is....i am a polaris dealer...
1999 polaris big boss 1/4 throttle bog, 4 wheeler carb problem bogs out at 1/4 throttle, atv backfires at over 15 mph bogging, atv bogs acceleration, atv bogs acceleration backfire, atv carb bogs at throttle, atv carburetor bogs acceleration, atv idles when give throttle it backfires, bayou 1/4 throttle bogging, fourwheeler bogs, kawasaki kfx 400 idles but backfires on throttle, kfx 400 back fires and bogs down, kfx 400 backfires, kfx 400 backfiring idle just fine, kfx 400 bogs below 1/4 throttle, motorcycle bogs at 1/4 throttle, polaris 4wheeler hesitating giving gas, polaris predator 1/4 throttle, polaris predator 500 four wheeler starts and backfires when given throttle, polaris throttle bogs
