Old 03-31-2010, 09:15 AM
jeff3541108's Avatar
Member #3682
changing fluids polaris scrambler I need some help
Can you tell me the proper steps/locations to change the fluids on my 05 scrambler 500 4x4. Thanks
Old 03-31-2010, 04:21 PM
The Kid's Avatar
Member #3743
motor oil = drain the oil tank put new filter on and there is a drain plug on the motor under the pull rope starter
front hubs = there is a allen head plug on the hub( one on each side) fill it up then turn hub to the 3 o'clock position and let extra out
front diff= drain plug on bottom fill plug on the right side of diff fill to top of side plug
trans = drain plug on bottom fill plug on the side or it has a dip stick on the right hand side (cant remember)
The Kid
heel clicker
Warn 2500 puller outter
SS108's
29.5's Laws skinny/fat
rubber down custom intake
homemade exhaust snorkel
rad. relocated up top
chains on front & rear A arms
swaybar removed
Old 03-31-2010, 05:46 PM
Parsons Synthetics's Avatar
Member #3476
Send a message via Skype™ to Parsons Synthetics
If I can help with AMSOIL fluids for your scrambler, just let me know.
Take care,
Old 10-28-2011, 02:51 PM
scrambler21's Avatar
Member #16395
what type of fluid do u use for the front dif?
1997 polaris scrambler 500 oil drain plug
how to change fluids in polaris scrambler
how to change the oil on a polaris scrambler
how to drain oil on 1999 polaris scrambler
oil capacity 2001 polaris scrambler 500
polaris 1999 500 scrambler oil and filter
polaris scrambler 500 fluids
polaris scrambler 500 oil change
polaris scrambler 500 oil type
polaris scrambler 500 transmission fluid
polaris scrambler maintenance
polaris scrambler oil 4x4 change
polaris scrambler oil change
polaris scrambler oil change info
polaris scrambler oil filter
polaris scrambler oil type
polaris scrambler repair
polaris scrambler transmission fluid
polaris scrambler transmission oil
2007 800x2 fluids finishcarp ATV Repair and Maintenance 6 12-19-2009 12:37 AM
Changing solenoid on 2000 Sportsman 500 Uponone929rr ATV Repair and Maintenance 2 08-26-2009 06:38 AM
Changing oil krusty32 Polaris Sportsman 1 08-14-2009 03:24 PM
Changing rear brakes 87 2x4 Trailboss dblowry ATV Repair and Maintenance 2 06-21-2009 11:18 AM
polaris scrambler 4oo cdi fit on polaris trailblazer 250? trailblazerpr ATV Racing Discussion 2 06-12-2009 07:30 AM
