Old 04-01-2010, 02:46 PM
zman57's Avatar
Member #3924
2008 500 sportsman, blown oil line return
Ok guys, here I go again. Changed the oil in the 2008 sportsman 500 HO last Sunday, I drained the crankcase and cleaned the brass filter on the lower oil line from the oil tank. As the polaris instructions tell me I prime the oil pump for 15 seconds on initial startup after the change.
I could not tell if the pump was actually primed so I turned the motor off, re-clamped the oil line and was going to try to prime again but when I started the motor up, you guessed it the pressure blows a hole instantly on the upper line below the vise grip pliers.
I stopped at the dealer to try and buy another line because I believe this is somewhat a special line with a blow off vent for priming reasons. The parts guy can't find it on his shelf and gives me a 3/8 fuel line. I was not impressed with counter guy to ask for a whole lot of advice. That is why I am asking you guys for advice on this situation
My questions are, is this line going to be ok? Do I need to prime the system again.
I do not believe that I need to because when I removed the line the oil did not drain from the pump.
Old 04-01-2010, 04:10 PM
Cableguy657's Avatar
Member #3405
on mine there is a slit in it for venting, when i change the oil i clamped it closer to the tank before this vent.
after 15 seconds i shut mine off and when i unclamp the vent line i listen for a sucking sound indicating that it is primed.
I am sure that blueline15 will chime soon.
2011 850 XP EPS
Browning LE
27" XTR's
Atv Guru Cobra series brush guards
Warn XT30
F/R L&R Boxes
G3 60" plow
2012 RZR
Polaris Pursuit camo
Atv Guru Bumpers
Warn XT30
26" Grim Reapers
ss108
Racer Tech 2inch lift
Makin Trax springs
Old enough to know better but, still too young to care!
http://s859.photobucket.com/home/cableguy657/allalbums
Old 04-02-2010, 02:04 PM
zman57's Avatar
Member #3924
Update on the blown oil line,
The oil line that blew a hole in it under pressure when I clamped onto it with vise grips, was not the upper line on the tank, but it is the line on the top 1/3 of the tank.
It was'nt until today that I saw there was a upper line on the very top of the tank. (this line is not very easy to see, let alone find the pressure relief slit)
I replaced the blown line with a regular 3/8" fuel line that was given to me from the dealer.
Here are my questions again, Since I replaced that line, do I need to still prime the oil pump?
The replaced line, is that going to be OK or do I need to buy the Polaris line? The difference that I see is the PSI rating on the Polaris line is 50 psi, the other line is a standard fuel line I am not sure what the psi is.
2008 polaris ranger oil hose
crankcase psi on polaris ranger 500
hose on polaris ranger split
how oil lines go on a polaris 500 sportsman
oil change 2008 polaris sportsman ho
oil pressure problem for sportsman 500
oil return coming off polaris ranger
polaris 500 oil tank vent line
polaris ranger500efi find oil vent line pressure relief slit
polaris sportsman 500 crankcase pressure problems
polaris sportsman oil lines
polaris sportsman where is hose slit
priming oil line polaris 500
priming oil on 500 polaris ranger
sportsman 500 blown engine
sportsman oil vent line
where do the oil lines go on a polaris 500 sportsman
where is the vent line to the top of the oil tank on a 02 sportsman 700
why is there a slit in the oil line polaris
why is there a split in the oil tank vent hose polaris ranger
Fuel Line routing 500 Sportsman MJ_500ATP ATV Repair and Maintenance 4 02-16-2011 05:18 PM
Blown head gasket??? Jeff Wright Polaris Sportsman 5 09-04-2010 07:32 AM
Blown fuses eidsonben ATV Repair and Maintenance 5 03-04-2010 06:39 PM
Vent Line.... Ragelite Polaris Sportsman 2 09-14-2009 03:56 AM
line-x plastic body parts on polaris sportsman 700 dreich690 ATV New Members 2 01-03-2009 05:41 AM
