2005 polaris sportsman 500 ho 4 wheel drive problem - Polaris ATV Forum
Old 04-04-2013, 12:59 PM
zschettler_24's Avatar
Member #35298
Unhappy 2005 polaris sportsman 500 ho 4 wheel drive problem
my 2005 Polaris sportsman the 4 wheel drive works in low and high but will not work in reverse
when I put it in reverse the 4 wheel drive light comes on but will not go into reverse everything else works the override button and all the gauges
Old 04-04-2013, 01:11 PM
vortecz71wv's Avatar
Member #14032
Are you holding the override button in?
Matt
Sent from West 'by-God' Virginia!!!
Mine:
2011 Sportsman 800
Polaris Front Brush Guard, Polaris Rear Brush Guard, Polaris Rear Rack Extender, Polaris L&R Rear Cargo Box, Warn 2500lb winch, Winch Saver, Ricochet A-Arm Guards (www.TheATVSuperStore.com), 3-High Headlight Mod, 6000k HID kit, Rigid Ind. 2xDually w/ strobe box, UNI Air Filter, 26" GBC Dirt Commanders, 1" Billet Wheel Spacers (Front and Rear) HighLifter HD springs, Dalton Primary Spring O\BL, Realtree Seat custom cover, Polaris Handguards
Wife's
2011 Sportsman 550XP
Polaris Front Brush Guard, Polaris Rear Brush Guards, Polaris Rear Rack Extender, 26" GBC Grim Reapers, Viper Elite 3000lbs Winch w/ wireless, Polaris Handguards, 6000k HID Kit
Fuel It, Flog It, Feel It!
Old 04-04-2013, 01:14 PM
faawrenchbndr's Avatar
Member #34872
+1
2012 550 EPS LE, Blue Fire
Cecco frame braces
JCCapri bushing kit
Maxxis BigHorns
Ricochet skid plates (full kit)
Polaris rear rack extender
Polaris front brush guard
Warn ProVantage 2.5k winch
AmSteel Blue synthetic winch rope
Custom billet hawse fairlead
Denali 60" mid mount plow
Old 04-04-2013, 01:39 PM
Member #35298
yup im holding it in
Old 04-04-2013, 03:36 PM
InRBigness's Avatar
Member #7218
Check and make sure that the switch is not corroded. When you push it in and hold it does the motor still hit the override limit?
08 Sportsman 500HO
01 500HO Plow Machine
Old 04-04-2013, 06:28 PM
Member #35298
I checked the switch and its fine
Old 04-05-2013, 06:37 AM
roscoe's Avatar
Member #35303
U have a 2011 sportsman 500 and mine works fine in forward but in reverse it doesn't grab at first then when I let off the gas the front wheels lock in and I haven't figured that one out yet
roscoe's Avatar
Member #35303
I have not u have lol
Old 04-05-2013, 02:15 PM
Member #35298
lol tried that that doesn't work
Old 04-05-2013, 02:24 PM
roscoe's Avatar
Member #35303
I wonder if your sprag gear in the front diff is bad
05 polaris 800 no 4 wheele drive
05 sportman 500 fourwheel drive not workin
2005 polaris 4wheel
2005 polaris sportsman 500 4-wheel drive doesnt work in reverse
2005 polaris sportsman 500 ho no 4 wheel drive
2005 polaris sportsman ho 500 will not go in four wheel drive
polaris sportsman 2005 4x4 not working
polaris sportsman 4 wheel drive problems
polaris sportsman 500 4 wheel drive problems
polaris sportsman four wheel drive problem
polaris sportsman reverse problems 2005
1999 polaris sportsman 335 4 wheel drive not working langford ATV Repair and Maintenance 1 11-27-2012 04:20 PM
2000 polaris 500 sportsman ho with 4 wheel drive problems grizzlogger Polaris Sportsman 3 09-29-2012 02:17 PM
2005 Magnum 330 4-wheel drive issue.. carena_05 ATV Repair and Maintenance 2 07-09-2012 10:42 AM
89 2 wheel drive starting problem oldtimer58 ATV New Members 2 10-25-2010 10:18 AM
1999 scrambler 4 wheel drive problem matt ATV General Discussion 6 01-21-2010 05:28 AM
