2008 polaris sportsman 500 HO EFI fuel pump - Polaris ATV Forum
post #1 of 7 (permalink) Old 04-06-2013, 07:49 PM Thread Starter
cmruffin's Avatar
FIXED: 2008 polaris sportsman 500 HO EFI fuel pump
2008 Polaris Sportsman 500 HO EFI
It looks like I've got a bad fuel pump - voltage looks good at the connector but it won't pump gas. I pulled the pump from the tank but I'm having trouble locating a replacement part, does anyone know how to buy/replace the actual pump in the assembly?
The assembly has the following part numbers stamped on the top::
Polaris 2520794
Bosch f01rb0s139
788202
How do I locate a replacement? Are there any best known techniques for replacing the pump in the assembly?
ID:	11655   Click image for larger version
cmruffin is offline
post #2 of 7 (permalink) Old 04-06-2013, 09:01 PM
Boburk's Avatar
The only way Polaris sells it, is with the tank and all for about $500. There is a carter fuel pump folks here have had luck with, that sells for about $100. I have no personal experience with it, and am sure someone (AKStew) will be along shortly with a part number, etc.
Sean
_____
2008 Sportsman 300
- Purchased in 2012 with 25 hours on it
- UNI air filter
- Polaris 1500 winch
2011 X2 550
- Purchased in 2012 with 58 hours on it
- Viper 3500 winch
- Front lock and ride storage box
- Bighorn 2s all around
2012 RZR 570
- Purchased Dec 2013
- Viper Elite 3500 winch.
- Cooter Brown top
- EMP rear window
- Totron 30" curved spot light bar
2006 X2 500 (sold)
- Purchased in 2011 with 250sh hours and 2500sh miles
- 26" Trilobite HD tires on 12" SS108 rims
- Cabela's (Warn RT) 2500 winch
- Front rack extender
- Front brush guard
Boburk is offline
post #3 of 7 (permalink) Old 04-07-2013, 01:04 AM
Bruce! is offline
post #4 of 7 (permalink) Old 04-07-2013, 01:56 AM
AKStew's Avatar
Carter fuel pump #P72118.
Rockauto.com is a good place to get it.
2011 Sportsman 500 HO Touring: Polaris 3500 lb. Winch, Kimpex Adventure XL Trunk, 7" Passenger Foot Risers, UNI Foam Filter
2006 Sportsman 500 X2 EFI: Superwinch Terra 25 w/Synthetic Rope, Kolpin 4 gal Gas Pack, 3" Passenger Foot Risers, 3-Headlight Mod, K&N Filter
SOLD 2010 Sportsman 300: Polaris 2500 lb. Winch, Kolpin Rear Seat (for the dog), UNI Foam Filter
SOLD 2006 Sportsman 700 Twin EFI: 27" Mud-Lite XTR, Superwinch Terra 35 w/Synthetic Rope, Polaris HD Front Springs, OEM Front Bumper Guard, WES Rear Seat, Kimpex Fender Guards w/Footpegs, 3-Headlight Mod, K&N Filter, Symtec Heated Grips
AKStew is offline
post #5 of 7 (permalink) Old 04-07-2013, 06:38 PM Thread Starter
cmruffin's Avatar
After I got the actual pump out of the assembly it had the following markings:
Bosch F01R 00R 007
I couldn't find the Carter P72118 pump locally but it cross-referenced to an airtex E8198 at the o'reillys website so I decided to give it a try. Unfortunately that pump didn't work out in my model. The molded plastic assembly the pump fits into is designed around the inlet for the filter screen/sock, and it didn't allow the filter screen/sock to be attached once it was encased in the assembly.
I did however locate an airtex E8335 which cross-referenced down at o'reillys to a Bosch 69544 which I bought since it had a lifetime warranty. It turned out to be a drop-in replacement.
I'm back up and running! Thanks for your help on this it got me pointed in the right direction.
cmruffin is offline
post #6 of 7 (permalink) Old 04-08-2013, 12:16 AM
AKStew's Avatar
Sorry about the part number snafu and glad you were able to fix it despite my "help."
Stew
AKStew is offline
post #7 of 7 (permalink) Old 06-22-2013, 12:54 PM
Guero's Avatar
I just learned something else. In that fuel pump assembly, between the pump and regulator there is something encased in black housing. I think it is a filter. I had changed two pumps and it was still bogging, like 5 mph when hot. I tracked the restriction down to that component. I can't find info on it or replacement so I just drilled a hole in it. It is on my 08 500 x2, but my 07 doesn't have it. Thanks for info guys.
Guero is offline
Troubleshooting 2006 Sportsman 700 Fuel Pump, Fuel Gauge, and Fuel Pressure Regulator AKStew Polaris ATV How-Tos 21 07-24-2016 04:46 PM
2008 sportsman 500 ho efi - fuel pump Thewiseguy31 ATV Repair and Maintenance 0 03-08-2013 03:57 AM
2008 500 HO EFI touring fuel pump trouble Papa2012 ATV General Discussion 1 10-13-2012 03:51 PM
2004 polaris sportsman 700 efi fuel pump nmwapitihunter ATV Repair and Maintenance 3 01-10-2012 06:06 PM
2005 Polaris Sportsman 800 Fuel Pump kristynmatt ATV Repair and Maintenance 2 05-25-2011 01:00 PM
