only one front wheel pulling - Polaris ATV Forum
post #1 of 10 (permalink) Old 04-11-2013, 12:38 PM Thread Starter
chicknhawk1999's Avatar
Just replaced the rf cv axle boot put it all back together and now stuck in the mud and that wheel will not pull. 2000 sportsman 500
chicknhawk1999 is offline
post #2 of 10 (permalink) Old 04-11-2013, 07:31 PM
InRBigness's Avatar
Thanks for the update. We were wondering what was going on out there in the mud.
Seriously, there are a million threads about this. let us know what you have done to diagnose the issue and what you have done to try and fix it and we can jump in and give you some direction.
08 Sportsman 500HO
01 500HO Plow Machine
InRBigness is offline
post #3 of 10 (permalink) Old 04-15-2013, 12:06 PM Thread Starter
Ok finally had a chance to pull it apart today and noticed the washer with the 3 tits sticking up is bent Alittle bit. Would that cause it not to pull
post #4 of 10 (permalink) Old 04-15-2013, 02:22 PM
curtwpk's Avatar
Here is a good thread:
LINK
2011 850 X2
2012 550 XP with Turf Mode Conversion
curtwpk is offline
post #5 of 10 (permalink) Old 04-15-2013, 03:05 PM
InRBigness's Avatar
In a word yes that is the armature plate. If it is not flat it will not work properly. Read through the link in the above post and you will have a better understanding on how it works.
08 Sportsman 500HO
post #6 of 10 (permalink) Old 04-15-2013, 03:12 PM Thread Starter
Yeah Im going to. I see what i did.When i pulled the axle out that plate dropped and when i put the axle back in it was not lined up so it bent when i tightened it.
post #7 of 10 (permalink) Old 04-15-2013, 03:52 PM Thread Starter
Im pretty sure it is that peice since it worked fine before i pulled it apart. Im sire i didn't pull on the wires.
post #8 of 10 (permalink) Old 04-16-2013, 04:18 PM Thread Starter
Ok i put the new plate in today and still won't pull on tjats side. So i pulled both sides apart and it feels like the magnet pulls alot harder on the side that works. Could it be damaged wire thats not sending enough power down to that side. HELP PLEASE
post #9 of 10 (permalink) Old 04-17-2013, 08:49 AM
InRBigness's Avatar
check it with a meter. you should have 12v.
08 Sportsman 500HO
post #10 of 10 (permalink) Old 04-17-2013, 12:18 PM Thread Starter
Ok I checked I had 12v all the way down to the coil. So i think that the coil is bad.
front wheel popping when in 4wd 02 500 swamper29 ATV Repair and Maintenance 1 06-13-2012 05:32 AM
2000 335 Sportsman front left wheel pulling Thor2911 ATV Repair and Maintenance 12 04-04-2011 01:57 PM
01 Scrambler 500 4x4 left front wheel engages when in 2 wheel drive pontiac69 ATV Repair and Maintenance 5 03-23-2011 11:01 AM
01 Scrambler 500 4x4 left front wheel engages when in 2 wheel drive pontiac69 Polaris Scrambler 2 02-15-2011 04:22 AM
front wheel locking gordo1473 ATV Repair and Maintenance 2 03-02-2010 06:43 PM
