Old 04-05-2010, 04:09 PM
nicks500HO's Avatar
Member #4101
2004 sportsman 500 ho questions/concerns "newbiee"
Hey guys! my first time here....love the forums...ok i have a few questions...i just picked up a 2004.5 sportsman 500 ho with 300 hours and 2100 miles on it....now i want to create my own maintenance chart.....so i did the oil change/filter, new spark plug, transmission oil with polaris synthetic gearcase lube. after i did the tranny fluid change i went on to the front gearbox...now in my manual and i bought a clymers manual it says there is a fill plug and a drain plug....all i found was 1 plug on the left bottom of the gearbox... so i opened it and almost dry.....so i put oil in it level with the hole....is this right????
now i went on to the rear gearbox.....where the *** is the plugs for the rear gear box??? i could not find anything......i bought the polaris oil kit for the tranny and front and rear gearboxes and the jugs in it say Demand Drive Plus, ATV Angle Drive Fluid , and the synthetic tranny fluid....where does the angle drive and demand drive fluids go???
so i went on to grease the joints.......oh man....all i found were the 2 grease nips on the bottom of the front struts.....there is none on the u-joints or anytthing anywhere else .....is this normal guys?????
Please help me i have never owned an ATV before and am worried i am not doing the proper maintenance on the machine.....i dont want it to brake b/c of lack of maintenance..
Thanks In advance for your help guys!
Old 04-05-2010, 06:18 PM
4play's Avatar
Member #1644
I believe the rear diff and the tranny is all one piece is it not? also there should be 2 plugs on the front diff.... look really hard. i believe it's in a corner and hard to see.
Old 04-05-2010, 07:11 PM
Old 04-06-2010, 04:22 AM
nicks500HO's Avatar
Member #4101
Thanks Bruce
Old 04-06-2010, 02:09 PM
nicks500HO's Avatar
Member #4101
yea i searched and searched for it but could only find this one plug...
Old 04-06-2010, 03:33 PM
The Kid's Avatar
Member #3743
thats the fill plug
The Kid
heel clicker
Warn 2500 puller outter
SS108's
29.5's Laws skinny/fat
rubber down custom intake
homemade exhaust snorkel
rad. relocated up top
chains on front & rear A arms
swaybar removed
Old 04-06-2010, 05:19 PM
nicks500HO's Avatar
Member #4101
do you know where the drain plug is?
Old 04-09-2010, 07:59 AM
chicknhwk's Avatar
Member #3871
i always go to atvpartcenter.com and look at the microfiche diagrams when i need to find that kinda stuff..
Old 04-09-2010, 10:58 AM
nicks500HO's Avatar
Member #4101
awesome looked great thanks chickn
Old 03-05-2011, 11:13 AM
pol500's Avatar
Member #12635
do i have to remove the axles on a polaris 500 ho 2001 to repalce the bearings and seals
04 sportsman 500 manual
2004 500 ho sportsman
2004 polaris 500 ho
2004 polaris atv oil change
2004 polaris sportsman 500 ho
2004 polaris sportsman 500 ho fluid specs
2004 polaris sportsman 500 ho manual
2004 polaris sportsman 500 ho oil change
2004 polaris sportsman 500 ho owners manual
2004 polaris sportsman 500 ho service manual
2004 polaris sportsman 500 oil change
2004 polaris sportsman 500 owners manual
2004 polaris sportsman 500 repair manual
2004 polaris sportsman 500 service manual
2004 polaris sportsman 500ho atv repair manuals
2004 sportsman 500
how much oil does a 2004 polaris 500 h.o.
how to service 2004 polaris sportsman 500
where to grease 2004 sportsman 500
2006 Sportsman 700 EFI "dies above idle" NEED HELP ASAP FOR WEEKEND RIDE xlwater Polaris Sportsman 4 05-18-2011 03:30 AM
Sportsman 400 Don't Shut Off "sometimes" polarisjunk Polaris Sportsman 5 01-01-2011 06:32 PM
Want to "wake" up your 300 Hawkeye/Sportsman? Firehawk ATV Performance Modifications 8 05-04-2010 06:19 PM
95 700 Sportsman intermittent pod failure "HELP" bigtodd ATV Repair and Maintenance 3 02-21-2010 05:35 AM
Un "Sportsman" Like Conduct sporthog ATV New Members 1 09-01-2009 12:39 PM
