Setting up an oil pump - Polaris ATV Forum
post #1 of 5 (permalink) Old 04-06-2010, 06:11 PM Thread Starter
jakeameister's Avatar
Good day everyone
I am trying to revive a 1995 400L 2x4 it has not run in 5 years. The oil pump cable is rusted and the spring is broken. I am installing new parts and my question is how do I set it up. Do I turn the screw in all the way till it's closed and then back it off a couple of turns to open then hook up the cable.
My son had a book at one time but can not find it.
Any help would be greatly appreciated.
jakeameister is offline
post #2 of 5 (permalink) Old 04-06-2010, 09:43 PM
Bruce! is offline
post #3 of 5 (permalink) Old 04-07-2010, 07:43 AM
4getful2's Avatar
i believe the screw you are talking about is the air bleeder screw,take it all the way out and let the oil flow until you see no more bubbles,then put screw back in. after you have the cable installed and your idle set,then at idle adjust the pump ,you should see to slash marks (one on pump body and one on control ),line those up and you're done. you should still run premix 40 or 50 to 1, until you verify that the oil pump is working,usually 2 tankfuls and measuring the oil tank start and end, will give you an idea
4getful2 is offline
post #4 of 5 (permalink) Old 04-12-2010, 06:11 PM Thread Starter
Thank you
Thank you very much for the information. I really appreciate it. As soon as my parts come in I will give it a go. I will let you know how I make out.
post #5 of 5 (permalink) Old 12-03-2013, 05:23 PM
hawken's Avatar
I have a 95 sportsman 400 has always smoked a lot. how do i adjust the oil enjector.
hawken is offline
oil injection pump frony83 ATV Repair and Maintenance 4 05-19-2015 09:37 AM
03 600 water pump 2003600polaris ATV New Members 4 04-07-2010 07:18 PM
Oil Pump Question alaskabigbear ATV General Discussion 0 04-02-2010 04:53 PM
97 Xpress 300 - Carburetor Setting 2nd part Nandy Polaris Sportsman 1 02-25-2010 02:36 PM
polaris 500 water pump jpringle ATV General Discussion 2 06-21-2009 05:22 PM
