Old 04-10-2010, 02:44 PM
sped64's Avatar
Member #4213
rear 1/2 shaft removal problems
I just purchased a 2004 500 sportsman needed a few things battery,and right rear 1/2 shaft,swapped out battery machine is a beast.i tore down right rear,tried pulling axle out and it didn't move inner joint came apart leaving just the end in differential,how can I get this to pop out I am very familiar with 1/2 shafts have changed 100's in cars/trucks but this one has me flustered.I know one of you has encountered this so please help.thanks in advance for any input.
1/2 shaft on polaris
2004 polaris sportman driveshaft removal
axle removal
emoval of rear driveshaft on a 2004 polaris
polaris 1/2 shaft
polaris 1/2 shalft
polaris rear 1/2 shaft
polaris sportsman 600 rear shaft removal
rear drive shaft removal for 2004 polaris sportsman
right rear drive shaft, polaris atv
rear drive shaft removal 304ronnie ATV Repair and Maintenance 8 08-26-2011 11:18 AM
2002 Sportsman 700 rear drive shaft removal pbm1957 ATV Repair and Maintenance 5 01-20-2011 08:49 AM
u-joint in rear pro shaft[drive shaft] two as one ATV Repair and Maintenance 3 10-21-2009 07:43 PM
HELP, rear drive shaft removal. rust Polaris Sportsman 2 08-16-2009 03:58 PM
Help,need advice,rear drive shaft rust ATV Repair and Maintenance 10 08-15-2009 04:04 AM
