Mikuni Carb - Polaris ATV Forum
Old 04-10-2010, 06:29 PM
tomc3976's Avatar
Member #3848
Send a message via Yahoo to tomc3976
Mikuni Carb
Hi I have a 85 trail boss 250 2 stroke with carb issues. it wont idle at low rpm but does run very good at higher rpms, im not sure if the parts inside are the right ones or not but i have tried a 40 and a 45 pilot jet but still no change if i am reading them correct i have tried a 145 and a 230 main jet the 230 was just an extra. also tried with and without breather box. also how far should the jet needle go into the main jet? should it touch bottom? any info for this would be greatly appreciated as i dont know much about these type of carbs. one more thing it seems the only way to get it to start is with choke on and cover the carb warm or cold no difference.
Old 08-24-2011, 09:55 AM
2xturbo's Avatar
Member #17717
Idle
Tom i don't know what elevation you are at. I am at 4880ft and i run a Main jet 130 and a 35 pilot also the #2 clip position from the top. are elevation set up is at 8k-10k
Old 08-24-2011, 04:01 PM
mstermechanic907's Avatar
Member #17047
Send a message via MSN to mstermechanic907
you should be running a 145 main jet for 0 to 3000 feet. and a 30 pilot jet,check the color of your sparkplug and adjust for color,start at 1 1/2 turns from fully seated[air screw],and make sure that your float level height is adjusted .last i would check the oil pump make sure the pump mark lines up with the pump lever mark.
Old 08-25-2011, 03:41 AM
2xturbo's Avatar
Member #17717
oil
I agree with mastermech. set it up to your elevation. I am curious do the 86 Polaris trail boss have a low oil sensor which will make it not idle???
mikuni atv carb tuning
mikuni atv carbs
mikuni atv carburetor diagram
mikuni atv carburetors
mikuni carb polaris atv
mikuni carb tuning atv
mikuni carburetor adjustment atv
mikuni carburetor polaris atv
polaris atv carburetor diagram
polaris mikuni carb adjustment
polaris mikuni carb tuning
polaris mikuni carburetor adjustment
Carb settings needed and Carb issues NolenGerke Polaris Trail Blazer 7 01-27-2013 12:51 PM
New carb ridemhard Polaris Predator 15 03-17-2010 09:37 AM
Carb jet help KENinRI ATV Performance Modifications 4 01-26-2010 07:07 PM
95 425 mag carb cecilmhughes ATV Repair and Maintenance 4 01-10-2010 07:32 PM
500 Carb Question... Markystang Polaris Sportsman 2 09-21-2009 02:14 PM
