Mixing polaris 2 cycle oil - Polaris ATV Forum
post #1 of 12 (permalink) Old 05-25-2013, 05:55 PM Thread Starter
tekrsq's Avatar
Does anyone know if I can mix Polaris 2 cycle oil straight into the gas or does it have to go through their oil injection system. If I can straight mix it, how much would I need per gallon for a 32:1 and 40:1 ratio.
08 Sportsman 800 Touring- EPI clutch turning 27" Mega Mayhems, 2500lb Polaris winch, front & rear SATV brush guards, front rack extender, 3 headlight Mod, Quadovator temp gauge, RAC Engineering reverse/ work lights, EBC brakes, Triangle ATV Stealth Snorkels, RDC radiator relocation kit, ATVtrailtunes split tube system, 12" Totron LED lightbar
08 RZR 800- SATV +6 offset long travel kit, Rhino axles, Walker Evans shocks, QSC clutch turning 27" Mud-Lite XTRs, 3500lb Polaris winch, 09 RZR-S exhaust, EMP 1/2 windshield, Air box relocation w/ custom snorkels, EBC brakes, BoeschBuilt parking brake, ATVTrailtunes speaker set, dual LightItUpOffroad LED whips, 30" Totron LED lightbar, 2x3 OPT7 cubes
05 Scrambler 500- Polaris rear rack, Bear Claw tires, EBC brakes (the wife's bike)
Grandkids- 04 Predator 50 (70cc big bore kit), 05 Eton Viper 90R, 93 Yamaha PW50, 03 Yamaha PW50, 09 Kawasaki KLX 110- They're killing me, lol)
tekrsq is offline
post #2 of 12 (permalink) Old 05-25-2013, 06:21 PM
It's fine to just mix the fuel tank, but I'd get a block off kit for the oil injection.
There is 128 ounces in a gallon, so 128/32 = 4. 128/40 = 3.2. So you would mix 4 ounces of oil per gallon of gas for 32:1, and 3.2 ounces of oil per gallon for 40:1.
blueline15 is offline
post #3 of 12 (permalink) Old 05-25-2013, 06:42 PM Thread Starter
tekrsq's Avatar
Ok great. So it's just a standard 2 cycle mix. I wondered if the Polaris oil required a special mix. THANKS !!!
I'd love to find a block off plate for the little 50, but I haven't had any luck. I think I'm just going to plug the oil lines, and cap the port on the carb.
You think a 32:1 or 40:1 mix will be better for the 50 ?
tekrsq is offline
post #4 of 12 (permalink) Old 05-25-2013, 07:12 PM
Either is probably fine. I tend to error on the side of caution and would go more on the 32 side. Should be $2 spark plugs, and we're only talking an ounce of oil per gallon of gas in a 50, compared to running leaner and possibly burning out the top end.
Just my .02
post #5 of 12 (permalink) Old 05-26-2013, 05:28 AM
I don't know about Polaris oil but there is usually a big difference between 2 cycle injector oil and premix oil. Most injector type 2 stroke oil won't stay in suspension very well and will separate out. It's made to run through an injector system not premix. If your gonna premix your gas I'd probably use something like Belray or Klotz 2 cycle oil that is intended for premixing.
polman500 is offline
post #6 of 12 (permalink) Old 05-26-2013, 11:41 AM Thread Starter
tekrsq's Avatar
That's a good point. I'll have to look into that. I have about 6 qts of Polaris injector oil that I did not want to just trash now that I'm doing away with the oil injection on our 50. I still have a couple of PW50s that I can use it in for now, but I'm going to convert them over too...eventually.
tekrsq is offline
post #7 of 12 (permalink) Old 05-26-2013, 01:16 PM
InRBigness's Avatar
Why convert them if they are working? I had a couple of two strokers for 20 years and never had an issue and reading here it seems to be a very reliable system. It is also waaaay more convenient.
08 Sportsman 500HO
01 500HO Plow Machine
InRBigness is offline
post #8 of 12 (permalink) Old 05-26-2013, 02:19 PM Thread Starter
tekrsq's Avatar
The oil injection on our Predator 50 is not working. I believe the plastic gear is likely broken. I haven't pulled the pump out to confirm this, but a little research found this is a very common problem on the Polaris engines. Either way, it stopped working, burned up the piston, and I don't plan to chance it again.
The Yamaha PW50's use a metal gear on their pumps and rarely go bad. I really don't need to convert them, but I'm trying to keep things simple. I don't like having to remember "unmixed gas for this one, mixed gas for that one". It's not that big a deal for me, but it seems to be for the grandkids and their parents. I can already see somebody putting unmixed gas in the predator and burning up another piston.
tekrsq is offline
post #9 of 12 (permalink) Old 05-26-2013, 04:52 PM Thread Starter
tekrsq's Avatar
I just checked my oil. 5 of the quarts just say it is VES Gold "2 cycle oil for all 2 cycle engines", while the last quart is still VES Gold, but specifically says "for oil injected 2 cycle engines".
Both oils look the same, but who knows. Anyway, don't know if there is really a difference, but if it is, at least I've only got 1 quart of injector oil.
tekrsq is offline
post #10 of 12 (permalink) Old 05-27-2013, 06:57 AM
RVS Performance's Avatar
When I got rid of all my Polaris sleds with VES I had many gallons of gold oil left. Been mixing it into the chainsaw, dirtbikes, weed whip, and vintage sleds for a few years now. No issues and all running perfect.
RVS Performance is offline
Polaris 2 cycle oil question chief1983 ATV Repair and Maintenance 4 01-27-2013 10:28 PM
1994 Polaris 300 2 Cycle Wont Start Chevytech49 ATV Repair and Maintenance 16 11-22-2012 06:09 AM
polaris magnum 2x4 4 cycle 07asgillum ATV Purchasing and Price 1 05-30-2012 10:11 PM
Mixing oil in gas mud99 ATV General Discussion 8 01-07-2011 08:26 AM
Polaris only 2 cycle oil? RedRocket ATV Repair and Maintenance 4 08-08-2010 12:09 PM
