coolant problem - Polaris ATV Forum
Old 05-27-2013, 09:20 AM
05sportsman600's Avatar
Member #36323
coolant problem
I just did a coolant change on my 05 sportsman 600 and filled it back with the polaris antifreeze and bled the radiator, so yesterday when i was riding i shut the atv off and i noticed coolant shooting out of the vent hole in the res.i have also been noticing that the fan is mostly always on while riding. But there is No HOT alert on the speedo. Any help would be good . Thanks
Old 05-27-2013, 03:13 PM
AKStew's Avatar
Member #5212
You probably need to clean the radiator fins completely and/or the radiator cap is probably bad. I had the same symptoms and a new cap fixed fixed it.
Stew
2011 Sportsman 500 HO Touring: Polaris 3500 lb. Winch, Kimpex Adventure XL Trunk, 7" Passenger Foot Risers, UNI Foam Filter
2006 Sportsman 500 X2 EFI: Superwinch Terra 25 w/Synthetic Rope, Kolpin 4 gal Gas Pack, 3" Passenger Foot Risers, 3-Headlight Mod, K&N Filter
SOLD 2010 Sportsman 300: Polaris 2500 lb. Winch, Kolpin Rear Seat (for the dog), UNI Foam Filter
SOLD 2006 Sportsman 700 Twin EFI: 27" Mud-Lite XTR, Superwinch Terra 35 w/Synthetic Rope, Polaris HD Front Springs, OEM Front Bumper Guard, WES Rear Seat, Kimpex Fender Guards w/Footpegs, 3-Headlight Mod, K&N Filter, Symtec Heated Grips
Old 05-27-2013, 03:15 PM
AKStew's Avatar
Member #5212
BTW I'm moving to SLC in about 6 weeks. Looking forward to a longer riding season down there.
Old 05-27-2013, 10:44 PM
Member #36323
The radiator is clean. And when your bleeding your radiator does the reservior have to empty becuase i bleed the radiator with the reservior filled up?
There ls alot of good trails near SLC
2010 polaris sportsman 300
bleeding radiator on sportsman 600
change coolant on sportsman 600
coolant problem polaris atv
what are signs of bad radiator cap on polaris atv
Coolant? TrailExplorer ATV Repair and Maintenance 10 08-12-2012 07:19 PM
Bubbles in oil and coolant problem lowrider284 ATV Repair and Maintenance 10 09-26-2011 08:21 PM
Coolant maverick11 ATV Repair and Maintenance 6 05-03-2011 04:56 AM
Allied Electricals: Coolant Pump | Industrial coolant Pump in India Bangalore Allied Site Issues & Suggestions 1 11-19-2010 02:13 PM
Coolant buckfever5 ATV Repair and Maintenance 4 05-08-2010 11:34 AM
