Seal leaking, front differential - Polaris ATV Forum
Old 04-11-2010, 12:18 PM
HappyCamper's Avatar
Member #2191
Send a message via AIM to HappyCamper
The front differential seal is leaking on my 2008 Polaris Sportsman 700 X2. How hard is it to replace the seal? How do I disconnect the front drive shaft so I can put a new seal in?
Also the front differential filler plug is very hard to get to. I am thinking I could replace the plug with a hose fitting and run a hose straight up to where the ADC filler bottle is. Then I could change the front differential fluid faster and easier. I don't know how much pressure is in the front differential. Any ideas?
Much Thanks!
2008 Polaris Sportsman 700x2
2008 Polaris Sportsman 90
2005 Bombardier Outlander 400XP
Old 04-17-2010, 10:26 PM
Member #2191
got it all fixed. Easier to do than I thought it would be. I put in a "filler tube" so it is easy to fill and change the demand fluid. I used a clear line so I could see when it was full.
2006 sportsman x2 front differential seals
changing the front seal to a razor
front diff leaky seal after changing in polaris 550 atv
how do you replace the oil seal in the front end on a 2009 polaris 800
how to change differential seal on 2010 polaris 550 sportsman
how to replace front drive shaft seal on 20012 polaris sporstsman 500
how to replace seal differential atv front
how to seal out of rzr differential
oil seals for front differential on polaris atv
polaris sportsman front differential seal
replace front differential seal polaris sportsman
sportsman front differential replace
500 Scrambler front hub seal instructions Firemanf58 ATV Repair and Maintenance 8 04-10-2010 06:33 PM
mechanical seal jmar73 ATV Repair and Maintenance 2 03-02-2010 04:18 PM
Gas leaking only when running?? lostcreek21 ATV Repair and Maintenance 3 02-13-2010 11:14 AM
rear output shaft seal liv2plant Polaris Sportsman 2 02-04-2010 04:47 PM
Fuel Tank Foam Seal ???? Farmer Green Polaris Sportsman 7 01-25-2010 07:27 PM
