WIX or Fram filter I can use with Sportsman 500 2003 - Polaris ATV Forum
post #1 of 12 (permalink) Old 05-29-2013, 10:10 AM Thread Starter
tdarden3k's Avatar
Looking for a less expensive oil filter to use on my 03 Sportsman 500 and I was wondering if any one knew the Wix or Fram or ??? equivalent. Also I want to move from conventional oil to Synthetic Mobil 1. Are there any precautions that I need to follow when moving from conventional to Synthetic ?
Also can someone tell me what the oil capacity is for this model ?
tdarden3k is offline
post #2 of 12 (permalink) Old 05-29-2013, 10:29 AM
MustBeNice's Avatar
Filter cross reference, look here..... Polaris Oil Filter Cross-Reference - MudInMyBlood Forums
I used a Purolator Classic 3.5" Filter (# P14610) on my last atv changes. I choose the 1" longer as it should have more filter element = more filtering surface area capability and more oil volume capacity.
As to dino to synthetic.... you shouldn't have any issues at all, it should actually be better for the machine!! However, I'm personally a fan of sticking to an oil brand and grade once switched over!
Should take 2 quarts (or 1.9 actual).
So..... at Walmart you should be able to get two quarts Mobile1 0W40 (@ about $7.00 each) and a Purolator Filter (@ about $4.50) plus local tax out the door for about $18-20 bucks, and it should be just as good as the $40 Polaris kit (with the spendy pretty box & blue bottles/green caps) you can get at your nearest dealer..... or 1/2 price for an equivalent product!
May also be a good idea to pick up a filter socket that fits these filters!!
Matthew "MustBeNice"
Mods: Polaris 2500HD Winch - MotoAlliance Line Stopper - Glacier3 60" Plow - Polaris Rack Extenders - Polaris Bumpers - LowPro Shield - Polaris Hand Guards - Warning Debadge - 3Way Head Light (Relay) - Cabelas Mirrors - Wes Ind. Std Seat/Box - Kolpin Fuel Pack Jr - 26" Kenda BearClaw HTR Tires - HighLifter HD Springs - MotoAlliance Sirius 6" Pro LED Light Bar
MustBeNice is online now
post #3 of 12 (permalink) Old 05-29-2013, 10:35 AM Thread Starter
tdarden3k's Avatar
That is Great ! Thanks a lot for the info.
post #4 of 12 (permalink) Old 05-29-2013, 11:53 AM
FuntanaS's Avatar
The 5 quart jug of Mobil1 0w-40 is now only $22.47 at walmart.
FuntanaS is offline
post #5 of 12 (permalink) Old 05-29-2013, 12:02 PM
MustBeNice's Avatar
Very True.... I think the 5 qrt jug I bought a couple weeks ago was $24.97. But still cheap enough, not to mention should cover 2 changes and extra to spare.
When I did oil on my machine(s), I picked up the 5 qrt jug and the two Purolator Classic filters (was planning on supplies for two changes, than picked up a second machine) and was only in it for about $35 vs the $80 I would have had into Polaris kits...... Hmmmm you do the math!
post #6 of 12 (permalink) Old 05-29-2013, 07:55 PM
Wix # 51358 Fram # 6607
Russ C is offline
post #7 of 12 (permalink) Old 05-29-2013, 09:12 PM
hatzie's Avatar
I'm not sure where the K&N number in the prior post came from...
I use the K&N 303 motorsports filter with a 17mm sheet metal nut on the end for easy removal.
Vehicle applications for K&N Part KN-303
The stock filter is rumored to be made by WIX.
WIX oil filter cross reference
hatzie is offline
post #8 of 12 (permalink) Old 05-30-2013, 07:04 AM
faawrenchbndr's Avatar
I won't use Fram on a lawn mower!
Junk!
2012 550 EPS LE, Blue Fire
Cecco frame braces
JCCapri bushing kit
Maxxis BigHorns
Ricochet skid plates (full kit)
Polaris rear rack extender
Polaris front brush guard
Warn ProVantage 2.5k winch
AmSteel Blue synthetic winch rope
Custom billet hawse fairlead
Denali 60" mid mount plow
faawrenchbndr is offline
post #9 of 12 (permalink) Old 05-30-2013, 07:13 AM
JCooperpcola's Avatar
Re: WIX or Fram filter I can use with Sportsman 500 2003
Junk!
Agreed.
Sent from my Huawei-U8665 using Tapatalk 2
JCooperpcola is offline
post #10 of 12 (permalink) Old 05-30-2013, 10:12 AM
tt425's Avatar
In my experience Fram is junk. Wouldn't put it on a bicycle or wheelbarrow. Wix offers less expensive filters can be found at carquest and napa auto parts. Carquest red filter is R85358 and napa silver is 21358.
2008 Dodge Caliper
2010 Chevrolet Equinox
2004 Honda ForemanES 400 4x4
(Currently I don't own a Polaris but I work on them all the time and get to ride cutomers for test rides. Maybe soon I will be a Polaris owner.)
tt425 is offline
stock air filter or a after market filter ? 2003trailblazer250 ATV Performance Modifications 7 06-16-2014 07:59 AM
fuel filter and oil line filter 2003trailblazer250 Polaris Trail Blazer 2 08-05-2012 07:18 AM
Fram or polaris oil filter? pureXP Polaris XP 26 07-16-2012 06:51 PM
oil filter sportsman 600 ? mtalp50 ATV Repair and Maintenance 8 11-21-2010 01:52 PM
97 Sportsman 500 oil filter banderson58 ATV Repair and Maintenance 7 08-01-2010 01:30 PM
